Observer gkubota
AXI Slave memory-mapped to master AXI-Stream
I  need IP with an AXI memory-mapped slave interface on one side and an AXI-Stream interface master interface on the other side.  I have found documentation on the axi-mm2s-mapper in product guide PG102.
 http://www.xilinx.com/support/documentation/ip_documentation/axi_mm2s_mapper/v1_0/pg102-axi-mm2s-mapper.pdf)
However, I can't find any other info on this IP.  Is this currently available?
I was also looking at the AXI Datamover, but if I read that correctly, it appears that the memory-mapped interface is a master, correct?
Is there some other IP that is currently available that will do what I want?
Observer razi.marjani
Re: AXI Slave memory-mapped to master AXI-Stream
HI gkubota
1. Memory Map side of DataMover is Master.
2. Check BlockRam With Axi_MM Interface. It may be work for you.
This is discussed a lot if you spend some time searching.
Or start reading about the AXI DMA, AXI Datamover, AXI Stream FIFO, and AXI VDMA
www.xilinx.com
Observer gkubota
It looks like the AXI Stream FIFO can do the conversion that I need.
I'm curious though; is the axi-mm2s-mapper that I linked to in my initial post an IP block that is available now?  It looks like that might be useful.
Newbie evanpan
Thanks for your nice sharing. But do you have any experience about pdf conversion? I want to look for a fine pdf to image converter whose way of processing is simple and fast. Any suggetsion will be appreciated. Thanks in advance.
