Visitor perig
AXI Traffic Generator - Advanced Mode without Processor Intervention
Hello all,
I am currently trying to configure an AXI Traffic Generator IP for functioning in advanced mode without processor intervention.
PG125 specifies on page 27 :
"Advanced/Basic Mode without Processor Intervention
1. Edit the default generated mif files (default_<componentname>_cmdram.mif, default_<componentname>_prmram.mif, default_<componentname>_mstram.mif) to match desired profile."
But I cannot seem to find those mentioned files to edit. So where should I look for them ?
Thank you very much.
Périg
Voyager
Voyager
Re: AXI Traffic Generator - Advanced Mode without Processor Intervention
@perig
  I've also had trouble finding the exact files as described in the documentation, but a similar set of files are found under the project folder, ie. <project>.srcs/sources_1/ip/axi_traffic_gen_0/*.mem and also under netlist/ with the .coe extension.
  If you'll be editing those files by hand, you may want to use a tool I've released to make the job easier: https://github.com/patocarr/axi-traffic-gen
-Pat
https://tuxengineering.com
Visitor perig
Thank you for your answer patocarr.
I also found the files you mentioned but they are not the right ones (because re-created each time you re-compile your project).
And thanks for the tool, it could be useful.
Périg
