AXI VDMA
I have incorporated the VDMA into my design. I doesn't work so I've enabled the debug. I get the following:
AXI_VDMA - Partial Register Dump (uBaseAddr = 0x43000000):
PARKPTR = 0x00000000
S2MM_DMACR = 0x000101CA
S2MM_DMASR = 0x00004141
S2MM_STRD_FRMDLY = 0x00001E00
S2MM_START_ADDR0 = 0x10000000
S2MM_START_ADDR1 = 0x107E9000
S2MM_START_ADDR2 = 0x10FD2000
S2MM_HSIZE = 0x00001E00
S2MM_VSIZE = 0x00000438
MM2S_DMACR = 0x00010002
MM2S_DMASR = 0x00004041
MM2S_STRD_FRMDLY = 0x00001E00
MM2S_START_ADDR0 = 0x10000000
MM2S_START_ADDR1 = 0x107E9000
MM2S_START_ADDR2 = 0x10FD2000
MM2S_HSIZE = 0x00001E00
MM2S_VSIZE = 0x00000438
S2MM_HSIZE_STATUS= 0x00000000
S2MM_VSIZE_STATUS= 0x00000000
AXI_VDMA - Checking Error Flags
S2MM_DMASR - ErrIrq
S2MM_DMASR - EOLEarlyErr
S2MM_DMASR - DMADecErr
MM2S_DMASR - ErrIrq
MM2S_DMASR - DMADecErr
AXI_VDMA - Clearing Error Flags
S2MM_DMASR = 0x00000041
MM2S_DMASR = 0x00000041
I have analysed all these registers & settings and I can see I'm getting all sort of errors. The difficlulty I'm having is knowing how to fix them. Its interseting that the debug clears the errors and reruns it. When it reruns the status reporrts that the S2MM and MM2S have both halted. Both of them are reporting aVDMA Decode error. This occurs if the address request is not a valid address. What does this mean and how can I fix it?
