Participant selwyn
AXI4-lite regarding Interrupt controller
Hi ,
    AXI-System does not support interrupt package for the custom ip peripheral is it? Apparently i need to edit the mhd of my custom IP peripheral in order to connect to the axi_intc(interrrupt controller) in XPS . After connection, and exporting to SDK, apparently there is not way to enable the interrupt in the SDK as the SDK never create a vec ID for my custom peripheral or any enable_interrupt function,etc. Is there any a guide on this or alternative methods. By the way i am using virtex 7 series. It will be better if there is refer to examples or links liike virtex and kintect instead of zync or zedboard as they have a different ways of enabling the interrupts and the functions they used are different.
Re: AXI4-lite regarding Interrupt controller
hi,
refer to the procedure documented in this link http://www.xilinx.com/support/answers/51138.html
--hs
hi,
--hs
Participant selwyn
    The zip file , after tried importing, it works fine. What if i need to add in additonal slave registers inside the peripheral for more complex application. Is there a unique way to create this peripheral from scratch in xps that will auto generate the driver for the SDK?
hi,
glad that the example works as expected.
in this case, you should modify the rtl and rescan the repositories to reflect the same in the IP
-hs
