About soft TEMAC
Can someone give me a tutorial for total dummies on how to create implement and use axi ethernet and dma with microblaze?Thanks!
Re: About soft TEMAC
There are few tutorials
http://www.fpgadeveloper.com/2014/08/using-the-axi-dma-in-vivado.html - to create dma in vivado
http://www.fpgadeveloper.com/2008/10/tri-mode-ethe​rnet-mac.html - about TEMAC (xps version but you will understand the concepts)
Praveen
Praveen
Thanks!
