Add new exist git repository on SDK 2016.4
Hi all
I'd like to add new exist git repository (to access http://....) on XSDK 2016.4.
However I only find add new git repository (to access file://...).
Can I add new exist git repository on XSDK 2016.4 ? If yes, how do I do it ?
Thank you.
Best regards,
check this post if it make sense for you
https://forums.xilinx.com/t5/Embedded-Development-Tools/SDK-2016-git/td-p/728937
Please refer to Using SDK with Revision Control SoftwareWorking with Git and Importing Projects from Git
This AR may help you  (https://www.xilinx.com/support/answers/66629.html)
Thanks and Regards
Balkrishan
Hi @balkris
Thank you for your quickly reply.
I already know the flow when I create new git repository as bere repository on my local disk.
My question is how do I set git repository information, which is like "git://example.com/foo.git" or "http://example.com/foo.git", on XSDK 2016.4.
I'd like to use my local GitBucket repository, which is similar GitHub (or GitHubEnterprise).
How do I do it ?
Thank you.
Best regards,
I understand how do I do it.
But I can not resolve my question
[clone from git repository(URI)]
1) XSDK -> Import -> Git -> Projects from Git
2) Input unique strings on "Clone URI" box.
3) Input some information on Source Git repository
4) Can not select any branch on Branch selection. No list data.
Why I can't select branch name ?
Thank you.
Best regards,
