Add source to project without copying xsct (SDK2019.1)
My folder structure looks like this
./app_proj
./bsp_proj
./hw_proj
./common/src
How can I add the files in ./common/src to my app_proj without copying them to app_proj(i.e "importsources")? These files are common to other application projects, which is why I do not want to copy them over to each app project.
I need the files to just be linked, not copied over.
Tags (2)
Hi @sdmello ,
Please check this forum post. Hope it helps you.
https://forums.xilinx.com/t5/Embedded-Development-Tools/xsdk-batch-import-sources-link-to-files/td-p/742063
Thanks & Regards
Anil B
