Added repository and rescanned, but new driver not showing up
I have followed AR# 54322.
I have taken a driver for the quad Spi flash.  I have taken the SPI_v4_1 and copied it into a directory named drivers, under my applications src directory. I then renamed the directory to SPI_v4_2.  Then added a local repository, pointing to the src directory, and did a rescan.
I then go to the BSP settings and go to the drivers, and try to select the 4.2 version.  Only the 4.1 version is showing in the drop down box.
Tags (3)
Forgot to mention using 2015.4
hi,
can you attach the workspace for further debug?
--hs
See attached
hi,
this is fixed. you did not copy the complete folder location. refer to the snapshot and the updated workspace.
--hs
hi,
one more important thing is to make sure that the repository is set correctly.
in my case, it is set to the path as shown here
--hs
