Adding Library to BSP
I'm trying to build a project via the xsct available sdk, and hsi commands automaticly in a tcl script.
I have problem with adding a library to the BSP via the hsi add_library command. I can't get it to save.
puts "Creating hw & bsp projects"
sdk set_user_repo_path $SW_CORE_0
sdk set_user_repo_path $SW_CORE_1
sdk create_hw_project -name $HW_PROJ -hwspec $HW_DEF
sdk create_bsp_project -name $BSP_PROJ -hwproject $HW_PROJ -proc $PROC -os $OS
#hsi create_sw_design $BSP_PROJ -proc $PROC -os $OS
puts "Modifying projects"
hsi set_repo_path $SW_CORE_0
hsi set_repo_path $SW_CORE_1
hsi open_hw_design $SDK_WORKSPACE/$HW_PROJ/system.hdf
hsi open_sw_design $SDK_WORKSPACE/$BSP_PROJ/system.mss
hsi add_library lwip140 2.1
puts [hsi get_sw_designs]
puts [hsi get_libs]
hsi close_sw_design [hsi current_sw_design]
hsi close_hw_design [hsi current_hw_design]
puts [hsi get_libs]
It seems like the change is not saved if you look at the output in the terminal to the right? And the checkbox is not ticked.
Screenshot from 2016-06-09 15:18:13.png
Re: Adding Library to BSP
I believe you need to add in:
generate_bsp [-dir <arg>] [-hw <arg>] [-hw_xml <arg>] [-sw <arg>]
[-sw_mss <arg>] [-proc <arg>] [-os <arg>] [-os_ver <arg>] [-compile]
[-quiet] [-verbose]
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_1/ug1138-generating-basic-software-platforms.pdf
