Adding a custom library to a custom IP (XPS 14.5)
I have used the Create/Import Peripheral Wizard to create a custom IP.  After I created the IP, I modified the user_logic.vhd file for a custom purpose that uses other .vhdl files as sub-modules.  Some of the sub-modules use a custom library that I have created, but I don't know how to add it to the XPS project via the .pao file since the .vhdl files of the custom Library are not located in the XPS Project folder.
Can anyone help me with adding my custom Library so that XPS will generate the bitstream for my project?  Thanks in advance!
