athukoralakasun
Adding a new Library to Xilinx SDK 2014.2
I created a simple library on linux intel machine using "arm-linux-gnueabi-gcc" compiler. Now i need to add this library and call its fucntions from my SDK 2014.2.
Can someone kindly tell me how to achieve this?
Thank you.
htsvn
hi,
did you check this link? this is referring to an older version but the procedure is same
http://www.xilinx.com/support/documentation/sw_manuals/xilinx11/SDK_doc/tasks/sdk_t_proj_libraries.htm
--hem
Anonymous
Not applicable
Hey, I have attached a tutorial that may help
athukoralakasun
Thanks for your reply.. Yes i checked that link before i post this. But i do not have that king of options in my SDK. I am programming the ARM core.
I have attached an image to show what options i get when i goto properties of a source file.
Thank you.
athukoralakasun
I found a place to apply the library i created. But when i add it, it gives an error saying
"arm-xilinx-eabi-gcc: fatal error: no input files" Can anyone tel me what that means?
my library name is "libchange.a" and the image attached shows how i insert the library in to the project.
Thank you.
