Observer rob_baker
Adding a simple peripheral causes Microblaze to hang
I know this will sound familiar if you have read any of my previous posts but I don't have long to get this working and I haven't worked with these for very long.
I thought that adding more FSLs was creating a problem (http://forums.xilinx.com/xlnx/board/message?board.id=EDK&thread.id=2111) but it seems that adding any IP has the same effect.
I wrote a small clock divider module, tested it and imported it into a working MB project. This module requires no software and no interaction from the CPU. It is only connected to the internal system via the sys_clk_s and to an external pin.
The divider is working as I see it on my 'scope now but I can't debug when this module is present. The Bootloop is marked for BRAM initialisation and I'm putting the main program into RAM at 0x44000000, I made the recommended RAM controller modifications to get this to work in the first place (although I don't know whether this is the same issue).
Someone must have experienced this before?
EDK 9.1.02i
Spartan 3E500 Starter kit
Many thanks,
Rob
Re: Adding a simple peripheral causes Microblaze to hang
Hi Rob,
Never heard of this issue.
Can you post your .mhs file here?
Göran
Observer rob_baker
With much rebuilding I have worked around the problem by using "mch_opb_ddr v1.00.a", the "c" and "b" revisions don't seem to work nicely with the Micron 46V32M16-6T memory device on my Spartan 3E500 RevD development board (Maybe everyone knew that but me? :D).
I still have the extra UCF entries (http://www.xilinx.com/support/answers/25390.htm) and fixed clock phase shift in "PARAMETER C_CLKOUT_PHASE_SHIFT = FIXED
PARAMETER C_PHASE_SHIFT = 45".
I haven't tried a build without those in yet but it definitely does more than it was. Odd how adding a simple peripheral did this, all it done was take sys_clk_s and divide it down.
From an archived project I think this MHS was from a build that stalled on debug.
Rob
Message Edited by rob_baker on 04-23-2008 08:30 AM
