Participant mberemand
Adding external include path to a BSP
I'm trying to include a new header file in boot.S that exists in a directory outside my workspace. I've tried adding an external include path to my BSP via Properties -> C/C++ Include Paths and Symbols -> Add External Include Path, and the path with its files shows up in BSP's Includes tree in the Project Explorer.
But the compiler still complains that there is no such file. The GUI for adding includes to a BSP is very different than for adding includes to any other kind of project, so it's very unintuitive. Do I need to be doing something different? I'm using XSDK 2017.2.
Re: Adding external include path to a BSP
Hi @mberemand,
Include paths added like this are not being passed to the compiler. We'll investigate this
In the meantime, you can add the include paths through BSP Settings => expand drivers => select cpu driver and add -Iinclude_path to extra_compiler_flags. Please replace include_path with the correct path. For multiple paths, you can use -I option for each path
You are right about this not being intuitive. We'll work on this
Hi @mberemand,
For anyone viewing this question, it is important to note that updating the extra_compiler_flags field will regenerate BSP sources and overwrite any changes, so stash them with git or save a copy elsewhere before doing this.
