Adding local software repository (for LWIP) does not bring in "Makefile.config" and "xlwipconfig.h" changes
I have created my version of the LWIP library and used Xilinx Tools > Repositories to add the path to Local Repositories. I have found that while some modified source files are being correctly copied, my changes in  "Makefile.config" and "xlwipconfig.h" are not being pulled in. In both files, the only change I have made is defining a macro. Is there a reason for this, and how can I work around this?
Tags (3)
Hi meenal_burrows@waters.com
Not sure about specifically LWIP but I would bet the generation scripts might be overwriting your files. Did you take a look to the TCL files and check if those are overwriting them?
Ibai
Hi Ibai
Thank you for the reply. Which Tcl files do I need to check?
Kind regards
Meenal
