Address for Custom IP memory space
I am developing a sample program that will demonstrate the ability of transferring data between PowerPC and Custom IP using bram. I have a few questions how the brams are implemented, and how to access them.
(1) I generated two dual-port bram using core generator. Each bram has width of 2 byte, and depth of 160k. If I understand this correctly, each bram should have a total size of 2*160k = 320kbytes. However, in the information section from the block memory generator, it says it needs to use 80  of the 36K BRAMS to implement this. The total size of these bram is 80 * 36K = 2880K ?
(2) Another question is to what address do I use to address these 2 brams. I understand that I can use something like:
TESTMEMORYVHDL_mReadMemory(XPAR_TESTMEMORYVHDL_0_MEM0_BASEADDR)
 to address the first element in the first bram, and use "XPAR_TESTMEMORY_VHDL_0_MEM1_BASEADDR" to access the second bram since the signal Bus2IP_CS will be set correctly. However, how do I access the next element within the bram, Do I add 1, 2, or 4 to the base address?
(3) Since Bus2IP_Addr and Bus2IP_Data both are32-bit. I need to trim the signals to feed into the brams.
   buffer0_addra   <= Bus2IP_Addr(C_SLV_AWIDTH-20 to C_SLV_AWIDTH-3);
   buffer1_addra   <= Bus2IP_Addr(C_SLV_AWIDTH-20 to C_SLV_AWIDTH-3);
   buffer0_dina    <= Bus2IP_Data;
   buffer1_dina    <= Bus2IP_Data;
 The reason I used C_SLV_ADWITH-3 was because that's how the sample code (if I used the sample bram code for memory space) trims the address signal. Also, I tried to do buffer0_dina <= Bus2IP_Data(0 to 15), it doesn't seem to work. What are the correct ways to pass these signals to bram
Advisor
Advisor
(1) The RAMs are 36Kbits each, and you're asking for 320KBytes. Absolute minimum utilization for 320KBytes would be 320*8/36 = 72 BRAMs. However, this is only manageable in the awkward 9-bit, 18-bit, or 36-bit addressing modes. In the more easily-used 1-bit or 16-bit modes, the BRAM capacity is only 32Kbits each, and so 320KBytes requires 80 of them.
Thank you so much for the reply. I totally forgot about bit vs byte.
Since then, I have trimmed my Bus2IP signals like following:
   buffer0_addra   <= Bus2IP_Addr(C_SLV_AWIDTH-19 to C_SLV_AWIDTH-2);
   buffer1_addra   <= Bus2IP_Addr(C_SLV_AWIDTH-19 to C_SLV_AWIDTH-2);
   buffer0_dina    <= Bus2IP_Data(16 to 31);
   buffer1_dina    <= Bus2IP_Data(16 to 31);
   mem_IP2Bus_data(0 to 15) <=  X"0000";
   mem_IP2Bus_data(16 to 31) <= buffer0_douta when (Bus2IP_CS(0) = '1') else
	                        buffer1_douta when (Bus2IP_CS(1) = '1') else
				 			 (others => '0')
However, when my C program does the following
    for (index = 0; index < numData; index++){
    	TESTMEMORYVHDL_mWriteMemory(XPAR_TESTMEMORYVHDL_0_MEM0_BASEADDR+(memoryOffset*index), index);
    	data[index] = TESTMEMORYVHDL_mReadMemory(XPAR_TESTMEMORYVHDL_0_MEM0_BASEADDR+(memoryOffset*index));
I have tried with memoryOffset = 1,2,4 (I think it should be 2 in this case since word size for the bram is 2 byte). However, when I print the variable "data" out. The result is not what I expect.
Any help is greatly appreciated. Thank you very much.
I was playing around with the lines :
I wasn't sure whether I needed Bus2IP_Data(0 to 15) or Bus2IP_data(16 to 31). So I was trying different combinations but failed and went ahead and did some hardcoding:
  buffer0_dina <= x"F0F0" when (Bus2IP_Addr = x"41000000") else
                  x"F2F2" when (Bus2IP_Addr = x"41000002") else
                  x"F4F4" when (Bus2IP_Addr = x"41000004") else
                  (others => ('1')) when (Bus2IP_Addr(30) = '0') else
                  (others => ('0'));
if I understand correctly, if I do "mrd 0x41000000" it supposed to return F2F2F0F0 [0x41000000 is the base address of that memory defined in XPS].
However, the following result returned:
>> mrd 0x41000000 10
41000000: 0000F0F0
41000004: 0000F4F4
41000008: 0000FFFF
4100000C: 0000FFFF
41000010: 0000FFFF
41000014: 0000FFFF
41000018: 0000FFFF
4100001C: 0000FFFF
41000020: 0000FFFF
41000024: 0000FFFF
It seems like I could not modify the first 16-bit word within any of the 32-bit word.
Can someone tell me what I did wrong please ? Any help is greatly appreciated. Thank you very much.
