Alternative to interrupt-driven XUartLite_RecvByte() function?
Hello everyone,
I have what I think is a fairly straightforward question, I just can't find the documentation to answer it myself and was hoping someone has this knowledge from experience.  Is it possible that in place of the function  "XUartLite_RecvByte()" one could utilize the following:
char commandstr[32];
if( !XUartLite_IsReceiveEmpty(BaseAddress) )
         commandstr = XUartLite_ReadReg(BaseAddress, 0);
Is it possible to utilize the USB_Uart input as a non-interrupt driven input with a structure such as the one above utilizing the two given Uart functions?
Re: Alternative to interrupt-driven XUartLite_RecvByte() function?
Hi @liv37916
To be honest I'm not sure what are you trying to implement with that function :)
XUartLite_RecvByteis a blocking function that reads the Rx FIFO of the UART. Are you trying to create a non blocking function with the same purpose? in that case you function seems to be correct.
Just take into account that FIFO is one byte width so it does not take too much sense to store in a uint32_t variable ;)
Ibai
My apologies, that was meant to be "uint32_t commandstr" such that the register contents of the USB_Uart register were stored.
Hi @liv37916
Ibai
Ibaie,
I was trying to create a non-blocking function with the same purpose, although my function turned out to be extremely inefficient in comparison and I actually returned to using XUartLite_RecvByte() after figuring that out. Thank you very much for your reply, I had actually changed the storage to a uint8_t variable before reading this. Your post was great ideas for me all around, I appreciate you taking the time!
