Observer jacko0088
Am I going out of memory? ZYNQ7010 (ZTurn Board)
Hello all!
Now that all works as expected, I wish to share which should be my last problem here:
I'm using memcpy inside a for loop, which should run until an high N number is reached.
Launching it this way it just freeze when i = 1536 is reached
My question is: knowing I should have 1024MB of RAM, and DDR option is enabled into my a basic Zynq PS Design. Am I going out of memory? Is this trying to copy data into OCM or enabling DDR gives the possibility to run on external RAM by default?
int N = 1048576;
for (i = 0; i < N; i++) {
		memcpy(&V[i * 32], X, 128);
		xor_salsa8(&X[0], &X[16]);
		xor_salsa8(&X[16], &X[0]);
Thank you all!
jacko0088
Scholar u4223374
Re: Am I going out of memory? ZYNQ7010 (ZTurn Board)
What is the definition (type/size) of "V", and what is its address in memory?
Observer jacko0088
It gets launched in this way
core(uint32_t *X, uint32_t *V, int N)
This is X
uint8_t X[32*4] = {
		0x2c, 0xea, 0xa9, 0x0e, 0x59, 0x44, 0x8a, 0x45, 0x31, 0x89, 0x2e, 0xac, 0xf5, 0xb8, 0x7b, 0x22,
		0x63, 0xfe, 0xb1, 0xf2, 0x78, 0xca, 0xf4, 0x65, 0x0a, 0xe8, 0x3e, 0xc1, 0xb9, 0xa8, 0xd6, 0x9d,
		0x62, 0x09, 0xa7, 0x37, 0x6e, 0x55, 0x24, 0xce, 0xaf, 0x81, 0x90, 0x16, 0x4c, 0x6c, 0xa0, 0x73,
		0xbe, 0xfb, 0xef, 0x7f, 0x14, 0x86, 0x18, 0x90, 0x52, 0x41, 0x9f, 0x49, 0xcf, 0x00, 0x4f, 0x17,
		0xa9, 0x89, 0x2f, 0x5a, 0x71, 0xd1, 0x98, 0x9f, 0x82, 0x07, 0xf5, 0x2f, 0xb1, 0x51, 0xc5, 0xc8,
		0xa2, 0xfb, 0x4a, 0xcf, 0xf0, 0x45, 0x97, 0x08, 0x1f, 0x3b, 0x55, 0x37, 0xec, 0x0e, 0xa6, 0xbc,
		0x25, 0xd2, 0x3e, 0x19, 0xa1, 0x2d, 0x4c, 0x0d, 0x74, 0x06, 0x67, 0x4a, 0x5c, 0x64, 0x20, 0x44,
		0x7e, 0xad, 0x2e, 0x43, 0x96, 0x84, 0x0b, 0xa7, 0x34, 0x23, 0x99, 0x1d, 0xde, 0x14, 0x2b, 0x84,
This is what I'm passing as parameter for uint32_t *V
(void *)scratchpad
Which is just something like this:
unsigned char *scratchpad;
scratchpad = malloc(size + 63);
Hi @jacko0088
Did you made any progress on this? I'm just curious to see if you found the root cause or still struggling with this :)
Ibai
Ibai
Observer jacko0088
Went on vacation 4 days after this post was maded, now I'm back home but..nope. Still stuck. (and feeling a bit stupid too because maybe it's a simple thing) :(
Hi @jacko0088,
Ok let me try to test it on my end and I will try to give you some feedback.
Hope you had great holidays :)
Ibai
Ibai
Observer jacko0088
Thank you! I'm trying it over PS, then I wish to port it on PL… :)
Hi @jacko0088,
Taking a look to you code still is not clear the amount of memory you are allocating for V.
In the loop you are trying to access up to 33554336 elements in the array so that means you should be allocating (N*32*4) bytes.
Ibai
Ibai
Observer jacko0088
Hi Ibaie!
size should be equals to
N * 32 * sizeof(uint32_t)
Hi @jako0088,
So is (size + 63) equal to that amount of bytes? does it work if you use that value?
Ibai
Ibai
Observer jacko0088
It does not :(
Scholar ericv
@jacko0088
did you check if the returned value of malloc() is not NULL.?
Your heap may not be large enough.
Observer jacko0088
I've not, I'll check tonight!
