squallkin
An error message when generate the netlist
Dear all
When I am going to generate the netlist, the problem showed as below:
Running synthesis...
bash -c "cd synthesis; ./synthesis.sh"
./synthesis.sh: line 2: $'\r': command not found
./synthesis.sh: line 4: $'\r': command not found
Release 9.1i - xst J.30
Copyright (c) 1995-2007 Xilinx, Inc.  All rights reserved.
ERROR:Xst:427 - Entry File system_xst.scr
 not found
./synthesis.sh: line 11: syntax error: unexpected end of file
make: *** [implementation/system.ngc] Error 2
Done!
I don't know why there is a such problem. Is that relay to the licences ?
Thank you.
htsvn
Can you check if this AR works http://www.xilinx.com/support/answers/24134.htm
Hem.
htsvn
Hem.
cidacadvir
Exactly the same problem, and the AR solution doesn't works for me. (system variable SHELLOPTS with value igncr doesn't change anything)
Thank you
Message Edited by cidacadvir on 11-12-2008 06:43 AM
shaiku
I know this is old now, but I had the same problem and the AR fixed it.  I did have to close EDK and start it up again before the fix went into effect, however.
8. If XPS was open, restart XPS so that it will recognize the new environment variable.
