buddha1987
Voyager
Voyager
Any demo codes to implement USB or Ethernet in ZC702 to do data transfer?
Hi, is there demo codes which implement USB or Ethernet in ZC702 to do data transfer from board to computer?  I try to learn how to use the periperal in the board but I found there is no too much demo project to show how to do operations in these periperal (Only uart).
Thanks very much.
buddha1987
Voyager
Voyager
Anybody can help?
buddha1987
Voyager
Voyager
If somebody can suggest like which function or which file in BSP I can use, that will be great. Then I can check the file or function to see how to do data transfer.
Thanks very much.
ywu
I would suggest you run Xilinx Open source Linux on ZC702, which allows you to transfer file/data between PC and the board easily.
Thanks very much.
Cheers,
Jim
