Anybody knows how to solve this error?
I am using a custom board, which includes XILINX fpga(xc4vfx100).
i want to access the FLASH memory(s29jl064h), using XPS for reading/writing data of the look up table during the execution of that code in Power PC.
I have  created new IP core, which will access the flash, when i make a new hardware in HARDWARE>>CREATE or IMPORT PERIPHERAL.
after creating the IP I did the following:
edited pcores \my_flash_v1_00_a\data\my_flash_v2_1_0.mpd file
and added flash ports
edited \pcores\my_flash_v1_00_a\hdl\vhdl\my_flash.vhd
and added user ports and port mapping statement
edited \pcores\my_flash_v1_00_a\hdl\vhdl\user_logic.vhd
 and added flash port defnition in 'user ports' area,'user signal declarations' and 'user logic implementation'.
I have IMPORTED the ipcore using the same wizard and also added it to the project.
still I am not able to BUILD the project: It show these ERRORS.:-
At Local date and time: Fri May 06 13:17:21 2011
 make -f system.make download started...
Running Xilinx Implementation tools..
xilperl C:/Xilinx/10.1/EDK/data/fpga_impl/manage_fastrunti​me_opt.pl -reduce_fanout no
xflow -wd implementation -p xc4vfx100ff1152-11 -implement xflow.opt system.ngc
Release 10.1 - Xflow K.31 (nt)
Copyright (c) 1995-2008 Xilinx, Inc.  All rights reserved.
xflow.exe -wd implementation -p xc4vfx100ff1152-11 -implement xflow.opt
system.ngc
PMSPEC -- Overriding Xilinx file <C:/Xilinx/10.1/EDK/virtex4/data/virtex4.acd>
with local file <c:/Xilinx/10.1/ISE/virtex4/data/virtex4.acd>
Using Flow File: F:/xps/implementation/fpga.flw
Using Option File(s):
 F:/xps/implementation/xflow.opt
Creating Script File ...
# Starting program ngdbuild
# ngdbuild -p xc4vfx100ff1152-11 -nt timestamp -bm system.bmm
"F:/xps/implementation/system.ngc" -uc system.ucf system.ngd
Release 10.1 - ngdbuild K.31 (nt)
Command Line: ngdbuild -p xc4vfx100ff1152-11 -nt timestamp -bm system.bmm
F:/xps/implementation/system.ngc -uc system.ucf system.ngd
Reading NGO file "F:/xps/implementation/system.ngc" ...
Loading design module "F:/xps/implementation/ppc405_0_wrapper.ngc"...
Loading design module "F:/xps/implementation/plb_wrapper.ngc"...
Loading design module "F:/xps/implementation/xps_bram_if_cntlr_1_wrapper​.ngc"...
"F:/xps/implementation/plb_bram_if_cntlr_1_bram_wr​apper.ngc"...
Loading design module "F:/xps/implementation/rs232_wrapper.ngc"...
Loading design module "F:/xps/implementation/generic_gpio_wrapper.ngc"..​.
Loading design module "F:/xps/implementation/sdr_sdram_custom_wrapper.ng​c"...
Loading design module "F:/xps/implementation/ppc405_0_iplb1_wrapper.ngc"​...
Loading design module "F:/xps/implementation/ppc405_0_dplb1_wrapper.ngc"​...
Loading design module "F:/xps/implementation/clock_generator_0_wrapper.n​gc"...
Loading design module "F:/xps/implementation/jtagppc_cntlr_0_wrapper.ngc​"...
Loading design module "F:/xps/implementation/proc_sys_reset_0_wrapper.ng​c"...
Loading design module "F:/xps/implementation/smflash_0_wrapper.ngc"...
Gathering constraint information from source properties...
Done.
Applying constraints in "system.ucf" to the design...
Resolving constraint associations...
Checking Constraint Associations...
WARNING:ConstraintSystem:135 - Constraint <INST: UniqueName:
   /system/EXPANDED/system/ppc405_0/ppc405_0\/IP...>: No instances of type FFS
   were found under block
   "ppc405_0/ppc405_0/IPLB0_PLBv46_Adapter_i/adapter_​cs_FSM_FFd7-In11"
   (type=LUT4_D).
   "ppc405_0/ppc405_0/IPLB_DUAL_PORT.IPLB1_PLBv46_Ada​pter_i/adapter_cs_FSM_FFd7-
   In11" (type=LUT4_D).
   /system/EXPANDED/system/ppc405_0/ppc405_0\/DP...>: No instances of type FFS
   "ppc405_0/ppc405_0/DPLB0_PLBv46_Adapter_i/Inst_mpm​c2_sample_cycle/sample_cycl
   e_or0000148_SW0" (type=LUT4_L).
   "ppc405_0/ppc405_0/DPLB_DUAL_PORT.DPLB1_PLBv46_Ada​pter_i/Inst_mpmc2_sample_cy
   cle/sample_cycle_or0000148_SW0" (type=LUT4_L).
   "ppc405_0/ppc405_0/IPLB0_PLBv46_Adapter_i/Inst_mpm​c2_sample_cycle/sample_cycl
   "ppc405_0/ppc405_0/IPLB_DUAL_PORT.IPLB1_PLBv46_Ada​pter_i/Inst_mpmc2_sample_cy
   "ppc405_0/ppc405_0/IPLB0_PLBv46_Adapter_i/dack_loa​d_en" (type=LUT4_D).
   "ppc405_0/ppc405_0/IPLB_DUAL_PORT.IPLB1_PLBv46_Ada​pter_i/dack_load_en"
   (type=LUT4_D).
   "ppc405_0/ppc405_0/DPLB_DUAL_PORT.DPLB_Replicator_​i/PLBC405DCUERR7"
   (type=LUT4_L).
   "ppc405_0/ppc405_0/IPLB_DUAL_PORT.IPLB1_PLBv46_Ada​pter_i/abort_qualified_SW1"
   (type=LUT4_L).
   "ppc405_0/ppc405_0/IPLB_DUAL_PORT.IPLB1_PLBv46_Ada​pter_i/abort_pending_or0000
   1" (type=LUT4).
   "ppc405_0/ppc405_0/IPLB_DUAL_PORT.IPLB1_PLBv46_Ada​pter_i/read_pipe_or00001"
   (type=LUT4).
   "ppc405_0/ppc405_0/DPLB0_PLBv46_Adapter_i/Inst_mpm​c2_sample_cycle/clear_count
   1" (type=LUT2).
   cle/clear_count1" (type=LUT2).
   "ppc405_0/ppc405_0/IPLB0_PLBv46_Adapter_i/Inst_mpm​c2_sample_cycle/clear_count
   1" (type=LUT2).
   "ppc405_0/ppc405_0/IPLB_DUAL_PORT.IPLB_Replicator_​i/PLBC405ICUADDRACK24"
   (type=LUT2).
   "ppc405_0/ppc405_0/IPLB_DUAL_PORT.IPLB_Replicator_​i/PLBC405ICUADDRACK23"
   (type=LUT4).
   "ppc405_0/ppc405_0/IPLB_DUAL_PORT.IPLB_Replicator_​i/PLBC405ICURDDACK20"
   (type=LUT2).
   "ppc405_0/ppc405_0/IPLB_DUAL_PORT.IPLB_Replicator_​i/PLBC405ICURDDACK19"
   (type=LUT4).
   "ppc405_0/ppc405_0/IPLB_DUAL_PORT.IPLB_Replicator_​i/PLBC405ICUERR20"
   (type=LUT2).
   "ppc405_0/ppc405_0/IPLB_DUAL_PORT.IPLB_Replicator_​i/PLBC405ICUERR19"
   (type=LUT4).
   "ppc405_0/ppc405_0/DPLB_DUAL_PORT.DPLB_Replicator_​i/PLBC405DCUADDRACK"
   (type=LUT4).
   "ppc405_0/ppc405_0/DPLB_DUAL_PORT.DPLB_Replicator_​i/PLBC405DCURDDACK11"
   (type=LUT4).
   "ppc405_0/ppc405_0/DPLB_DUAL_PORT.DPLB_Replicator_​i/PLBC405DCURDDACK5"
   (type=LUT4).
   "ppc405_0/ppc405_0/DPLB0_PLBv46_Adapter_i/dack_cnt​_not00011" (type=LUT4).
   "ppc405_0/ppc405_0/DPLB_DUAL_PORT.DPLB1_PLBv46_Ada​pter_i/dack_cnt_not00011"
   (type=LUT4).
   "ppc405_0/ppc405_0/IPLB0_PLBv46_Adapter_i/dack_loa​d_mux0000<0>" (type=LUT4).
   "ppc405_0/ppc405_0/IPLB0_PLBv46_Adapter_i/dack_loa​d_mux0000<1>" (type=LUT4).
   "ppc405_0/ppc405_0/IPLB0_PLBv46_Adapter_i/dack_loa​d_mux0000<1>_SW0"
   (type=LUT2).
   "ppc405_0/ppc405_0/IPLB_DUAL_PORT.IPLB1_PLBv46_Ada​pter_i/dack_load_mux0000<0>
   " (type=LUT4).
   "ppc405_0/ppc405_0/IPLB_DUAL_PORT.IPLB1_PLBv46_Ada​pter_i/dack_load_mux0000<1>
   " (type=LUT4).
   _SW0" (type=LUT2).
   "ppc405_0/ppc405_0/DPLB_DUAL_PORT.DPLB1_PLBv46_Ada​pter_i/Mcount_dack_cnt_xor<
   1>11" (type=LUT4).
   "ppc405_0/ppc405_0/DPLB0_PLBv46_Adapter_i/adapter_​cs_FSM_FFd2-In1"
   (type=LUT4).
   "ppc405_0/ppc405_0/DPLB_DUAL_PORT.DPLB1_PLBv46_Ada​pter_i/adapter_cs_FSM_FFd2-
   In1" (type=LUT4).
   "ppc405_0/ppc405_0/DPLB0_PLBv46_Adapter_i/PLB_MRdE​rr_reg_and00001"
   (type=LUT4).
   "ppc405_0/ppc405_0/DPLB_DUAL_PORT.DPLB1_PLBv46_Ada​pter_i/PLB_MRdErr_reg_and00
   001" (type=LUT4).
   "ppc405_0/ppc405_0/IPLB0_PLBv46_Adapter_i/Inst_mpm​c2_sample_cycle/ratio_minus
   1_sub0000<3>1" (type=LUT4).
   were found under block "ppc405_0/ppc405_0/IPLB0_PLBv46_Adapter_i/Result<3​>1"
   (type=LUT4).
esult<3>11"
   (type=LUT4).
   "ppc405_0/ppc405_0/DPLB0_WRDBUS_buf_gen[24].DPLB0_​WRDBUS_buf" (type=BUF).
   "ppc405_0/ppc405_0/DPLB0_WRDBUS_buf_gen[25].DPLB0_​WRDBUS_buf" (type=BUF).
   "ppc405_0/ppc405_0/DPLB0_WRDBUS_buf_gen[26].DPLB0_​WRDBUS_buf" (type=BUF).
   "ppc405_0/ppc405_0/DPLB0_WRDBUS_buf_gen[27].DPLB0_​WRDBUS_buf" (type=BUF).
   "ppc405_0/ppc405_0/DPLB0_WRDBUS_buf_gen[28].DPLB0_​WRDBUS_buf" (type=BUF).
   "ppc405_0/ppc405_0/DPLB0_WRDBUS_buf_gen[29].DPLB0_​WRDBUS_buf" (type=BUF).
   "ppc405_0/ppc405_0/DPLB0_WRDBUS_buf_gen[30].DPLB0_​WRDBUS_buf" (type=BUF).
   "ppc405_0/ppc405_0/DPLB0_WRDBUS_buf_gen[31].DPLB0_​WRDBUS_buf" (type=BUF).
   "ppc405_0/ppc405_0/DPLB0_WRDBUS_buf_gen[32].DPLB0_​WRDBUS_buf" (type=BUF).
   "ppc405_0/ppc405_0/DPLB_DUAL_PORT.DPLB1_WRDBUS_buf​_gen[53].DPLB1_WRDBUS_buf"
   (type=BUF).
   "ppc405_0/ppc405_0/DPLB_DUAL_PORT.DPLB1_WRDBUS_buf​_gen[54].DPLB1_WRDBUS_buf"
   (type=BUF).
   "ppc405_0/ppc405_0/DPLB_DUAL_PORT.DPLB1_WRDBUS_buf​_gen[55].DPLB1_WRDBUS_buf"
   (type=BUF).
   "ppc405_0/ppc405_0/DPLB_DUAL_PORT.DPLB1_WRDBUS_buf​_gen[56].DPLB1_WRDBUS_buf"
   (type=BUF).
   "ppc405_0/ppc405_0/DPLB_DUAL_PORT.DPLB1_WRDBUS_buf​_gen[57].DPLB1_WRDBUS_buf"
   (type=BUF).
   "ppc405_0/ppc405_0/DPLB_DUAL_PORT.DPLB1_WRDBUS_buf​_gen[58].DPLB1_WRDBUS_buf"
   (type=BUF).
   "ppc405_0/ppc405_0/DPLB_DUAL_PORT.DPLB1_WRDBUS_buf​_gen[59].DPLB1_WRDBUS_buf"
   (type=BUF).
   "ppc405_0/ppc405_0/DPLB_DUAL_PORT.DPLB1_WRDBUS_buf​_gen[60].DPLB1_WRDBUS_buf"
   (type=BUF).
   "ppc405_0/ppc405_0/DPLB_DUAL_PORT.DPLB1_WRDBUS_buf​_gen[61].DPLB1_WRDBUS_buf"
   (type=BUF).
   "ppc405_0/ppc405_0/DPLB_DUAL_PORT.DPLB1_WRDBUS_buf​_gen[62].DPLB1_WRDBUS_buf"
   (type=BUF).
   "ppc405_0/ppc405_0/DPLB_DUAL_PORT.DPLB1_WRDBUS_buf​_gen[63].DPLB1_WRDBUS_buf"
   (type=BUF).
   /system/EXPANDED/system/ppc405_0/ppc405_0\/PP...>: No instances of type FFS
   were found under block "ppc405_0/ppc405_0/PPC405_ADV_i/PPC405_ADV_i"
   (type=PPC405_ADV).
WARNING:ConstraintSystem:119 - Constraint <NET: UniqueName:
   /system/EXPANDED/ppc405_0_dplb1_PLB_MRdBTerm T...>: This constraint cannot be
   distributed from the design objects matching 'NET: UniqueName:
   /system/EXPANDED/ppc405_0_dplb1_PLB_MRdBTerm' because those design objects do
   not contain or drive any instances of the correct type.
ts do
ERROR:ConstraintSystem:59 - Constraint <Net xps_gpio_0_GPIO_d_out_pin LOC=am13
   |> [system.ucf(140)]: NET "xps_gpio_0_GPIO_d_out_pin" not found.  Please
   verify that:
   1. The specified design element actually exists in the original design.
   2. The specified object is spelled correctly in the constraint source file.
ERROR:ConstraintSystem:59 - Constraint <IOSTANDARD=LVCMOS33;> [system.ucf(140)]:
   NET "xps_gpio_0_GPIO_d_out_pin" not found.  Please verify that:
Done...
Checking Partitions ...
Processing BMM file ...
Checking expanded design ...
WARNING:NgdBuild:443 - SFF primitive
   'xps_bram_if_cntlr_1/xps_bram_if_cntlr_1/INCLUDE_B​URST_SUPPORT.I_SLAVE_BURST_
   ATTACH/I_DBEAT_CONTROL/I_DBEAT_CNTR/STRUCTURAL_A_G​EN.I_ADDSUB_GEN[4].FDRE_I'
   has unconnected output pin
WARNING:NgdBuild:452 - logical net 'N34' has no driver
WARNING:NgdBuild:452 - logical net 'N35' has no driver
WARNING:NgdBuild:452 - logical net 'N36' has no driver
WARNING:NgdBuild:452 - logical net 'N37' has no driver
WARNING:NgdBuild:452 - logical net 'N38' has no driver
WARNING:NgdBuild:452 - logical net 'N39' has no driver
WARNING:NgdBuild:452 - logical net 'N40' has no driver
WARNING:NgdBuild:452 - logical net 'N41' has no driver
WARNING:NgdBuild:452 - logical net 'N42' has no driver
WARNING:NgdBuild:452 - logical net 'N43' has no driver
WARNING:NgdBuild:452 - logical net 'N44' has no driver
WARNING:NgdBuild:452 - logical net 'N45' has no driver
WARNING:NgdBuild:452 - logical net 'N46' has no driver
WARNING:NgdBuild:452 - logical net 'N47' has no driver
WARNING:NgdBuild:452 - logical net 'N48' has no driver
WARNING:NgdBuild:452 - logical net 'N49' has no driver
WARNING:NgdBuild:478 - clock net SDR_SDRAM_CUSTOM_mpmc_clk_90_s with clock
   driver
   clock_generator_0/clock_generator_0/Using_DCM1.DCM​1_INST/Using_BUFG_for_CLK90
   .CLK90_BUFG_INST drives no clock pins
Partition Implementation Status
  No Partitions were found in this design.
NGDBUILD Design Results Summary:
  Number of errors:     2
  Number of warnings: 572
One or more errors were found during NGDBUILD.  No NGD file will be written.
Writing NGDBUILD log file "system.bld"...
ERROR:Xflow - Program ngdbuild returned error code 2. Aborting flow execution...
make: *** [__xps/system_routed] Error 1
Done!
The Complete error log is  at:
http://forums.xilinx.com/xlnx/attachments/xlnx/EDK/19165/1/error.txt
Your error relates to the pins of xps_gpio_0_GPIO_d_out_pin, not the Flash Memory Custom IP.
You assigned a pin location in UCF but it seems this pin is trimmed in the netlist.
You can take a look at your synthesized GPIO core netlist(ngc) or the report files (srp) in synthesis directory to find the clue of why it's trimmed.
If this pin is not used in your design, remove the UCF pin location assignment.
Ya , u were right.  .. i got the error corrected.. forgot to add fpga_0_ before gpio in .UCF.
How did u come to know?
