golson
Are there ways to do conditional compilation of MHS and UCF
  We would like to take a ML510 system design and a corresponding custom board design (similar but with differences).
And create a single project that can accomodate both designs.  Using something similar to what is C Code.
such as #ifdef  and #ifndef.
We would like to so this in the UCF file and also maybe not as important but would be helpful if we could do this also
in the MHS file since the files will be different as well.
Thank You,
johnmcd
A long time ago I created a perl script to do this. I've attached the perl script and it contains some usage info in the comment section. Use at your own risk. This script is by no means supported by Xilinx.
Using the script, you would have your master ucf/mhs. Add your #ifdef, #ifndef, #else, #endif, #include to this master file. Then run the script on the master file with the defines that you want the #if... statements to react on. The script will output a new file that has the apropriate blocks of ucf/mhs commented out.
Let me know if it works out for you.
johnmcd
golson
Hi John,
  Thank you for the script.  I will give it a try.  I am not too familiar with perl yet.  I took the Idea
from this script and created a C file to do something similar to this.
Thank You,
  Gary
