Array and xil_printf problem with Microblaze and ML505
I'm using the Virtex-5 ML505 board. I've loaded Microblaze onto a single-processor system. And written the following as the application code.
#include "xparameters.h"
#include "stdio.h"
#include "xbasic_types.h"
#include "xgpio.h"
#include "gpio_header.h"
#include "xsysace.h"
#include "sysace_header.h"
#include "uartlite_header.h"
int main (void) {
    Xuint32 i, *arr1;
    for(i=0;i<40;i++)
        arr1[i]=i;
    print("\r\n ARR1 ");
    print("\r\n **** ");
    for(i=0;i<40;i++)
        xil_printf("\r\n %d > %d", i, arr1[i]);
    return 0;
I think I should get the values 0-39 in the respective indices of the array. But I don't get the correct output on Hyperterminal. I get the outputs like 0, 1, 2, 3, 5, 6, 7, 8, 10, 11, 12, 13... (4, 9, 14 etc. skipped!) and some junk numbers in the later locatins (above 30 or so). Please help me troubleshooting it.
arr1 is not initialized, so you are writing to invalid locations. Instead of defining it as *arr1, use arr1[40]
I tried to use expressions like *(arr1+i) and arr1[i] both interchangeably and consistently. But, the output was the same as before.
Tags (4)
Historian
Historian
You miss vsiva's point.
When you declare the variable as
    Xuint32 *arr1;
you are not reserving any space for anything. All you've declared is a pointer to an unsigned integer. But that pointer isn't pointing to anything.
So when you do your for loop, and you access arr1[i], you are accessing garbage because  you never initialized arr1.
The suggestion to declare that array variable as arr1[40] is one you should heed.
-a
exactly do as suggested in the previous post...else check that uart settings match with the  hyperterminal connection settings, dat also sometimes causes the problem of no output.
Historian
Historian
That may be true but that's not his problem.
-a
Yes, I missed vsiva's point. So, I'll try to use malloc for initialization so that the pointer doesn't point to garbage.
Thanks! I'll get back to you all asap.
Or I'll use arr1[40] (as an array) throughout.. Then I think I would't have to initialize it.
Historian
Historian
This is the better solution. In general, in an embedded system with limited memory, you really want to avoid dynamic allocation (malloc and its friends). If you use static allocations (arr1[40]), the toolchain knows how much memory is required and after compiling and linking, they will tell you if your program will fit in your memory!
-a
Ok. I got it. Thanks! :)
How can i send a float to UART if I mapped the xil_printf function to RS 232 IP?(Note:sprintf has a too large memory footprint ).
Thank you!
This is an entirely different question and should be in its own thread. Locked.
