Observer m_nabil1974
Assembly code
hi guys;
I am new in the MicroBlaze world.
I read the Microblaze manuals and I can say that now I can write an assembly code for the MicroBlaze.
My problem is how can I use the EDK 9.2 tool to debug and compile my assembly code?
cheers
Re: Assembly code
To create an assembler application in XPS do the following:
1. Create a new software application project in XPS
2. Right click on the Software Project and choose "Set Compiler Options"
3. In the ´"Environment" tab, set the "Program Start Address" to 0x0
4. In the "Path and Options" tab, add -nostdlib for "Other Compiler Options to Append"
Now you can just add your assemble files as sources to your project and compile your application.
Make sure that you have "Mark to Initialize BRAM" on your software project.
The compiler option added in step 4, is to prevent the compiler for adding all C code initialization routines which would have messed up your assembler project.
if you have the extension ".S" for your assembler files, GCC preprocessing will occur and with a ".s" no preprocessing is perfomed.
Göran
Re: Assembly code
May I know why are you going for assembly rather than C code?
-XF
Re: Assembly code
You may find this useful:
http://forums.xilinx.com/xlnx/board/message?board.id=EDK&message.id=7706 (May I use MacroBlaze Assembly in SDK)
As XF implies, there are multiple reasons why C is generally recommended if you are just starting with MicroBlaze.
bt
Re: Assembly code
Many thanks for the valuable replies.Dear xiaofeip: actually, the reason behind using the assembly is my prior knowledge with the assembly programming from 8051 and PIC and of course the PicoBlaze.So I find it easier to manage my application with it eventhought I know it is very tedious way for many programmers.Dear timpe :I followed most of your links that you gave to me. Really, they are very helpful.  Regarding the compiler links, my questions are; Should I download the complier and then compile my assembly file with extension x.s?If so, what are the output files of this process?Or in other words, how can I include the assembler output into the EDK tool?Sorry for my lengthy questions.  Kind regards;
Re: Assembly code
Göran
Re: Assembly code
dear goran_bilski :
Thanks for the helpful reply.But I have a couple of questions.What kind of compilers do you suggest me to use?After the compilation is done; are there any additional files in addition to the file ".s" should be included to my project files?
