Automating SDK builds
I'm trying to create a build script for my C SDK project on windows.
I've checked here, but have been unable to find any help on building from the command line.
I then found this, and followed it's instructions, but it seems to just generate makefiles?  It doesnt actually create my .elf file.
(I created a .bat script version of it, and a .sh version run under cygwin.  The .sh version doesn't work, as it can't seem to find/use the java virtual machine on my windows computer)
So I've been thinking I can use that to generate a makefile for my project, and then call "make all" in cygwin to actually build the project and get my .elf file?
However this means I have to create symlinks so that the commands in the makefile call the right executables.  This seems like a messy way of doing things.
Am I going about this the right way, or are the commands described in the link supposed to actually build the project?
any help would be greatly appreciated
to go from XPS to SDK, you can use psf2edward command. See page 43:
http://www.xilinx.com/support/documentation/sw_man​uals/xilinx13_4/est_rm.pdf
To generate the application. You can use the appguru tool from command line. The appguru
will allow you to create the example designs (Hello_world, memory test, ect.) from the command line.
For help here, open an ISE shell and type appguru -help fro assistance using this.
Finally, to run libgen. again see the link above on page 87.
Hope this helps
