bzuiss
Automating SDK project configuration
I am looking to automate the configuration of SDK C projects, BSP, and HDFs, and I know the exact steps to use to configure everything in the GUI.
Is there a way to display the equivalent TCL commands that I can use to automate this process?  My end goal is to only have a handful of C source files that will be pulled in during each automated build.
Thanks!
stephenm
No, there is no great way to display the commands. You can try enable the trace in the window -> preferences -> xilinx SDK -> log information.
There is a SDK batch commands, you can find this in the SDK help. There is also an AR here:
https://www.xilinx.com/support/answers/66629.html
stephenm
bzuiss
Thank you for clarifying.
