Automatition with SDK, add repository
Looking to automate some of the things I do often in SDK whenever I create a new project.  One example of this is I often add a repository for creating a device-tree.
Can anyone help me add a repository using a command line input?  Or point me to some resources?
regards,
Chad
Scholar sampatd
Re: Automatition with SDK, add repository
You can use the XSCT command "sdk set_user_repo_path" or "hsi set_repo_path"
For more details, you can check:
http://www.xilinx.com/support/answers/64200.html
and
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_4/ug1138-generating-basic-software-platforms.pdf
Scholar stephenm
Also, see the attached PDF (and the accompanying zip files)
Thank you for your help.  I have been able to automate everything except the fsbl.
Here is a list of commands I run before getting an error
    sdk set_workspace ./
    sdk set_user_repo_path /export/repo_workaround/data-engine/software_firmware/data_engine_software/config/scripts/xilinx_repo_kernel_3.14
    sdk create_hw_project -name hw_platform_0 -hwspec $hdf
    sdk create_bsp_project -name device-tree_bsp_0 -hwproject hw_platform_0 -proc ps7_cortexa9_0 -os device-tree
  hsi::add_library xilffs
  hsi::add_library xilrsa
  sdk create_bsp_project -name fsbl_bsp -proc ps7_cortexa9_0 -hwproject hw_platform_0 -os standalone
  sdk create_app_project -name fsbl -app {Zynq FSBL} -proc ps7_cortexa9_0 -bsp fsbl_bsp -hwproject hw_platform_0 -os standalone
Specified template name 'Zynq FSBL' is not valid for configuration. Reason: This application requires xilffs and xilrsa libraries in the Board Support Package.. List of valid names are Empty Application, Zynq DRAM tests, Peripheral Tests, Hello World, Memory Tests, Dhrystone.
Failed to create Application project 'fsbl'.
Failed to create Application project fsbl.
Not sure how to generate zynq FSBL from the XSCT command prompt.
Scholar stephenm
Look at AR 64200 that was mentioned in an earlier post for this use case
