guy.berger
Azure NetX buffer descriptors error
I am using Zedboard (Zynq 7000) in my app plugged with ethernet cable as well as ThreadX and NetX libraries.
I am transmitting packets of frame data (frame size 576000 bytes) at 25 frames per second using NetX functionality over udp.
It all works fine for about 20 - 60 minutes but then suddenly i get the following error:
txsr=0x0, txqbar=0xFF10188, error_code=0x1
Receive buffer not available
 number of packets in the netx pool is 200.
number of buffer descriptors:
NX_DRIVER_TX_DESCRIPTORS   256
NX_DRIVER_RX_DESCRIPTORS   128
i'll note that the app does not receive any traffic directly (user defined) so I am not sure why the receive buffers run out...
I am using gstreamer as a player on a receiving PC.
Any guidance as to what could cause this problem will be appreciated,
katsuki
Hi @guy.berger
This is probably due to ThreadX and NetX libraries. You may contact GRAPE SYSTEMS INC. or the vendor of the Zedboard you bought.
Thank you
Please mark the Answer as Accept as Solution if information provided is helpful.
Don’t forget to reply, kudo, and accept as solution. If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
katsuki
Hi @guy.berger
If already issue has resolved, Kudo, and Accept as Solution.
If you have any questions, you can post them.
Thank you.
