BASE ADDRESS and HIGH ADDRESS in VIVADO 2018.2
Hi Everyone,
I am in a project with ARTIX 7,
When I create a Block IP and In Package IP, I can change Verilog Code,parameter,....,and Base Address
and High Address.But In "Editor Address" the offset address and high address, it's the same with Package IP ??
ex : In Packet Ip : Base Address :FF00_0000     in Editor Address  Offset Addr : 44A0_0000   with range 4k
                             High                :FF00_0FFF                                  High Addr     44A0_0FFF
When I read/write data on SDK, the address FF00_0000,FF00_0FFF is not work,
I don't understand both case,
If i have an answer,please tell me,
Thank you very much,
vanloc,
Re: BASE ADDRESS and HIGH ADDRESS in VIVADO 2018.2
Hi @vanloc_tc1
Could you elaborate and provide some screenshots of the issue? I mean, your description is bit confusing and is not easy to undestand. A good idea would be:
  1. Add screenshot of how address setting in the Package IP menu
  2. Add screenshot of address editor in the main design
  3. Add screenshot of the SDK view of the HDF file
Ibai
