BSP Generation Error
Hi All,
I am trying getting an Error while BSP Source Generation.
lwip-1.4.1/src/core/init.c:272:4: error: #error "lwip_sanity_check: WARNING: MEMP_NUM_TCP_SEG should be at least as big as TCP_SND_QUEUELEN. If you know what you are doing, define LWIP_DISABLE_TCP_SANITY_CHECKS to 1 to disable this error."
make[1]: *** [init.o] Error 1
'Building target: TCP_test.elf'
'Invoking: ARM v7 gcc linker'
arm-none-eabi-gcc -mcpu=cortex-a9 -mfpu=vfpv3 -mfloat-abi=hard -Wl,-build-id=none -specs=Xilinx.spec -Wl,-T -Wl,../src/lscript.ld -L../../TCP_test_bsp/ps7_cortexa9_0/lib -o "TCP_test.elf"  ./src/c5.o ./src/echo.o ./src/i2c_access.o ./src/iic_phyreset.o ./src/main.o ./src/message_rx.o ./src/message_tx.o ./src/platform.o ./src/platform_mb.o ./src/platform_ppc.o ./src/platform_zynq.o ./src/platform_zynqmp.o ./src/queue.o ./src/rtGetInf.o ./src/rtGetNaN.o ./src/rt_nonfinite.o ./src/sfp.o ./src/si5324.o   -Wl,--start-group,-lxil,-lgcc,-lc,--end-group -Wl,--start-group,-lxil,-llwip4,-lgcc,-lc,--end-group
c:/xilinx/sdk/2017.4/gnu/aarch32/nt/gcc-arm-none-eabi/bin/../lib/gcc/arm-none-eabi/6.2.1/../../../../arm-none-eabi/bin/ld.exe: cannot find -llwip4
collect2.exe: error: ld returned 1 exit status
make: *** [TCP_test.elf] Error 1
Appreciate your help!
Best Regards
Re: BSP Generation Error
Can you post the MSS file so we can see your LWIP config settings?
