Participant ilya1976
BSP building Error on SDK
Dear Support,
I am following the document UG980 "Board Bringup Guide" to build BSP for the ZC702 evaluation board on SDK 2013.4.
When I try to build Petalinux BSP project, I get the following error:
ERROR:EDK - petalinux () - can't read "env(PETALINUX)": no such variable
make: *** [ps7_cortexa9_0/lib/libxil.a] Error 2
ERROR:EDK - Error(s) while running DRCs.
make: Target `all' not remade because of errors.
Please help to solve the issue.
Thanks in advance
Re: BSP building Error on SDK
I'm also facing the same issue while building Petalinux BSP for KC705 platform. I'm using Petalinux SDK version 2013.04.
Error:
make -k all
libgen -hw ../petalinux_hardware_hw_platform/system.xml\
-lp G:/LINUX_SHARE/hardware/edk_user_repository\
-pe microblaze_0 \
-log libgen.log \
system.mss
libgen
Xilinx EDK 14.7 Build EDK_P.20131013
Copyright (c) 1995-2012 Xilinx, Inc. All rights reserved.
Command Line: libgen -hw ../petalinux_hardware_hw_platform/system.xml -lp
G:/LINUX_SHARE/hardware/edk_user_repository -pe microblaze_0 -log libgen.log
system.mss
Staging source files.
Running DRCs.
# Top Level BSP DRC for Petalinux...
# Created by: Michal Simek
# version: petalinux_v2_00_a
Windows
ERROR:EDK:3414 - Error(s) while running DRCs.
make: *** [microblaze_0/lib/libxil.a] Error 2
Any help will be appreciated.
-- mayankara
Community Manager
Community Manager
Please see the following theards. It might be helpful.
http://forums.xilinx.com/t5/Embedded-Linux/EDK-ERROR-petalinux-bsp-build/td-p/433672
Sikta
Hi Sikta,
Actually I build Petalinux SDK (v2013.04) on Ubuntu 14.04 (64-bit machine) running as virtual machine on windows7 (64-bit) host. I followed the steps mentioned in ug980 pdf.
I tried the steps asmentioned in the link also. Still struggling with the same error.
-- mayankara
Newbie simon_tseng
i have the same problem, did you found any solution?
