Observer pstootman
BSP: per-component compiler options?
Any way in SDK to compile just selected components of a BSP with different compiler flags ?
[extra compiler flags in BSP settings GUI is applied to ALL components]
I have unconfirmed suspicion 2016.1 openamp component of BSP library has a problem at the default -O2, I want to compile vast majority of BSP at -O2 for performance, and use -O0 just for openamp component. I post here about it;
https://forums.xilinx.com/t5/OpenAMP/2016-1-openamp-missing-memory-barrier/td-p/703108
Re: BSP: per-component compiler options?
Look at:
http://www.xilinx.com/support/answers/66629.html
