eyke.liegmann
Baremetal reset pending interrupt (edge-sensitive)
I am using a Zynq UltraScale+ and have an interrupt from PL -> PS which is connected to the pl_ps_irq0.
The interrupt is set to be sensitive on the positive edge. I know that I need to reset the pending interrupt, otherwise the interrupt will remain active forever.
My question is how to reset a pending interrupt? I found the register list in the TRM but I still dont know how to do it.
ericv
@eyke.liegmann  this doc all the info on the interrupt controller:
https://static.docs.arm.com/ddi0416/b/DDI0416B_gic_pl390_r0p0_trm.pdf
Section 3.2.7 - write at the correct register a 1 at the bit location of the interrupt # to clear.
eyke.liegmann
i should also mention that the interrupt is going to the R5 processor
eyke.liegmann
*push*
is there anyone who can help?
For zynq 7000 this is discussed and solved here:
http://zedboard.org/content/how-change-interrupt-trigger-type-risingfalling-edge-triggered
eyke.liegmann
can any xilinx employee comment on this?
ericv
