waldemar
Beginners problems with Ultrazed-eg
I'm a total beginner with these devices so there might be some very silly mistakes but hope I get some ansvers.
So I have Ultazed-eg and trying to get started with this device.
Installed programs that I have are all 2017.2.
So what I have done so far:
- Created a project on Vivado, Avnet UltraZed-3EG IO Carrier Card
- Added MPSoC to design
- Disabled AXI HPM0 PLD from configuration because I was told it could cause some problems because I'm not using it
- Disabled display port because I had problems with it
- Verified
- Created hdl wrapper
- Generated bitstream
- Exported HW
- Started SDK
- Created BSP with 32-bit compiler
- Created Hello World project
- Got this running via JTAG after these instructions http://zedboard.org/content/aes-zu3eges-1-sk-g-sktutorial20164-mask-poll-failed-address-0xfd4023e4-mask-0x00000010
- Copied .hdf to Ubuntu
- petalinux-create -t project -s uz3eg_iocc_2017_2.bsp --name test_boot
- petalinux-config --get-hw-description=/home/vk/project_1.sdk
- In config I set primary SD to boot image, kernel image, dtb image and root file.
- petalinux-build
- petalinux-package --boot --format BIN --fsbl ./images/linux/zynq_fsbl.elf --fpga ./images/linux/download.bit --u-boot
- Prepared 8GB SD card like here is instructed https://medium.com/developments-and-implementations-on-zynq-7000-ap/install-ubuntu-16-04-lts-on-zynq-zc702-using-petalinux-2016-4-e1da902eaff7
- Also took the root filesystem from the link above
- Copied files to BOOT and rootfs like in the link above
When I boot the device from SD-card I get following log:
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2017.10.16 11:47:36 =~=~=~=~=~=~=~=~=~=~=~=
Xilinx Zynq MP First Stage Boot Loader
Release 2017.2   Oct 16 2017  -  00:30:00
NOTICE:  ATF running on XCZU3EG/silicon v2/RTL5.1 at 0xfffea000, with PMU firmware
NOTICE:  BL31: Secure code at 0x0
NOTICE:  BL31: Non secure code at 0x8000000
NOTICE:  BL31: v1.3(release):0d9d51a
NOTICE:  BL31: Built : 07:09:33, Oct 16 2017
U-Boot 2017.01 (Oct 16 2017 - 00:08:24 -0700) Xilinx ZynqMP ZCU102 revB
I2C:   Error, wrong i2c adapter 0 max 0 possible
ready
DRAM:  2 GiB
EL Level:	EL2
Chip ID:	xczu3eg
MMC:   sdhci@ff160000: 0 (eMMC), sdhci@ff170000: 1 (SD)
SF: Detected n25q256a with page size 512 Bytes, erase size 128 KiB, total 64 MiB
In:    serial
Out:   serial
Err:   serial
Bootmode: SD_MODE1
Net:   ZYNQ GEM: ff0e0000, phyaddr 9, interface rgmii-id
eth0: ethernet@ff0e0000
U-BOOT for uz3eg-iocc-2017-2
ethernet@ff0e0000 Waiting for PHY auto negotiation to complete......................................... TIMEOUT !
Hit any key to stop autoboot:  4  3  2  1  0
Device: sdhci@ff160000
Manufacturer ID: 13
OEM: 14e
Tran Speed: 25000000
Rd Block Len: 512
MMC version 5.0
High Capacity: Yes
Capacity: 7.1 GiB
Bus Width: 8-bit
Erase Group Size: 512 KiB
HC WP Group Size: 8 MiB
User Capacity: 7.1 GiB WRREL
Boot Capacity: 16 MiB ENH
RPMB Capacity: 4 MiB ENH
reading image.ub
13269620 bytes read in 895 ms (14.1 MiB/s)
   Using 'conf@2' configuration
   Trying 'kernel@0' kernel subimage
     Description:  Linux Kernel
     Type:         Kernel Image
     Compression:  uncompressed
     Data Start:   0x100000d8
     Data Size:    13236736 Bytes = 12.6 MiB
     Architecture: AArch64
     OS:           Linux
     Load Address: 0x00080000
     Entry Point:  0x00080000
     Hash algo:    sha1
     Hash value:   09c88dbce0ccb941e8ab4be9be7e2a2d0416b9e1
   Trying 'fdt@0' fdt subimage
     Description:  Flattened Device Tree blob
     Type:         Flat Device Tree
     Data Start:   0x10c9fbd0
     Data Size:    31577 Bytes = 30.8 KiB
     Hash algo:    sha1
     Hash value:   190d7c5ed49d5b616a786c8a4d3322d92f04138b
   Booting using the fdt blob at 0x10c9fbd0
   Loading Kernel Image ... OK
   Loading Device Tree to 0000000007ff5000, end 0000000007fffb58 ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.0-xilinx-v2017.2 (vk@ubuntu) (gcc version 6.2.1 20161016 (Linaro GCC 6.2-2016.11) ) #1 SMP Sun Oct 15 23:58:04 PDT 2017
[    0.000000] Boot CPU: AArch64 Processor [410fd034]
[    0.000000] earlycon: cdns0 at MMIO 0x00000000ff000000 (options '115200n8')
[    0.000000] bootconsole [cdns0] enabled
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 128 MiB at 0x0000000078000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] percpu: Embedded 21 pages/cpu @ffffffc077f7c000 s48152 r8192 d29672 u86016
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 517120
[    0.000000] Kernel command line: earlycon clk_ignore_unused root=/dev/mmcblk0p2 rw rootwait
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] Memory: 1920412K/2097152K available (9020K kernel code, 574K rwdata, 2788K rodata, 512K init, 394K bss, 45668K reserved, 131072K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008950000   (  9024 KB)
[    0.000000]     .rodata : 0xffffff8008950000 - 0xffffff8008c10000   (  2816 KB)
[    0.000000]       .init : 0xffffff8008c10000 - 0xffffff8008c90000   (   512 KB)
[    0.000000]       .data : 0xffffff8008c90000 - 0xffffff8008d1fa00   (   575 KB)
[    0.000000]        .bss : 0xffffff8008d1fa00 - 0xffffff8008d8252c   (   395 KB)
[    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf01c00000   (    28 MB actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc080000000   (  2048 MB)
[    0.000000] Hierarchical RCU implementation.
[    0.000000] 	Build-time adjustment of leaf fanout to 64.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 99.99MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x171015c90f, max_idle_ns: 440795203080 ns
[    0.000003] sched_clock: 56 bits at 99MHz, resolution 10ns, wraps every 4398046511101ns
[    0.008265] Console: colour dummy device 80x25
[    0.012524] console [tty0] enabled
[    0.015888] bootconsole [cdns0] disabled
[    0.019798] Calibrating delay loop (skipped), value calculated using timer frequency.. 199.99 BogoMIPS (lpj=399996)
[    0.019814] pid_max: default: 32768 minimum: 301
[    0.019929] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.019939] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.020569] ASID allocator initialised with 65536 entries
[    0.021149] zynqmp_plat_init Power management API v0.3
[    0.021235] EFI services will not be available.
[    0.021692] Detected VIPT I-cache on CPU1
[    0.021723] CPU1: Booted secondary processor [410fd034]
[    0.022093] Detected VIPT I-cache on CPU2
[    0.022112] CPU2: Booted secondary processor [410fd034]
[    0.022473] Detected VIPT I-cache on CPU3
[    0.022492] CPU3: Booted secondary processor [410fd034]
[    0.022529] Brought up 4 CPUs
[    0.022564] SMP: Total of 4 processors activated.
[    0.022573] CPU features: detected feature: 32-bit EL0 Support
[    0.022583] CPU: All CPU(s) started at EL2
[    0.022601] alternatives: patching kernel code
[    0.023347] devtmpfs: initialized
[    0.027837] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.030839] xor: measuring software checksum speed
[    0.067873]    8regs     :  2111.000 MB/sec
[    0.107904]    8regs_prefetch:  1882.000 MB/sec
[    0.147940]    32regs    :  2594.000 MB/sec
[    0.187968]    32regs_prefetch:  2180.000 MB/sec
[    0.187981] xor: using function: 32regs (2594.000 MB/sec)
[    0.188080] pinctrl core: initialized pinctrl subsystem
[    0.188784] NET: Registered protocol family 16
[    0.210251] cpuidle: using governor menu
[    0.210478] Failed to initialise IOMMU /amba/smmu@fd800000
[    0.210668] vdso: 2 pages (1 code @ ffffff8008957000, 1 data @ ffffff8008c94000)
[    0.210695] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.211326] DMA: preallocated 256 KiB pool for atomic allocations
[    0.236983] reset_zynqmp reset-controller: Xilinx zynqmp reset driver probed
[    0.237412] ARM CCI_400_r1 PMU driver probed
[    0.240912] zynqmp-pinctrl ff180000.pinctrl: zynqmp pinctrl initialized
[    0.266768] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.332138] raid6: int64x1  gen()   372 MB/s
[    0.400240] raid6: int64x1  xor()   405 MB/s
[    0.468257] raid6: int64x2  gen()   617 MB/s
[    0.536300] raid6: int64x2  xor()   549 MB/s
[    0.604348] raid6: int64x4  gen()   901 MB/s
[    0.672399] raid6: int64x4  xor()   677 MB/s
[    0.740470] raid6: int64x8  gen()  1050 MB/s
[    0.808521] raid6: int64x8  xor()   684 MB/s
[    0.876610] raid6: neonx1   gen()   662 MB/s
[    0.944584] raid6: neonx1   xor()   695 MB/s
[    1.012676] raid6: neonx2   gen()  1069 MB/s
[    1.080705] raid6: neonx2   xor()   948 MB/s
[    1.148753] raid6: neonx4   gen()  1379 MB/s
[    1.216798] raid6: neonx4   xor()  1083 MB/s
[    1.284855] raid6: neonx8   gen()  1454 MB/s
[    1.352895] raid6: neonx8   xor()  1119 MB/s
[    1.352908] raid6: using algorithm neonx8 gen() 1454 MB/s
[    1.352920] raid6: .... xor() 1119 MB/s, rmw enabled
[    1.352932] raid6: using intx1 recovery algorithm
[    1.353690] SCSI subsystem initialized
[    1.353913] usbcore: registered new interface driver usbfs
[    1.353961] usbcore: registered new interface driver hub
[    1.354007] usbcore: registered new device driver usb
[    1.354092] media: Linux media interface: v0.10
[    1.354129] Linux video capture interface: v2.00
[    1.354168] pps_core: LinuxPPS API ver. 1 registered
[    1.354182] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.354214] PTP clock support registered
[    1.354250] EDAC MC: Ver: 3.0.0
[    1.354556] FPGA manager framework
[    1.354609] Advanced Linux Sound Architecture Driver Initialized.
[    1.354951] Bluetooth: Core ver 2.22
[    1.354981] NET: Registered protocol family 31
[    1.354994] Bluetooth: HCI device and connection manager initialized
[    1.355013] Bluetooth: HCI socket layer initialized
[    1.355029] Bluetooth: L2CAP socket layer initialized
[    1.355059] Bluetooth: SCO socket layer initialized
[    1.355683] clocksource: Switched to clocksource arch_sys_counter
[    1.355770] VFS: Disk quotas dquot_6.6.0
[    1.355821] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.361094] NET: Registered protocol family 2
[    1.361493] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    1.361626] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[    1.361904] TCP: Hash tables configured (established 16384 bind 16384)
[    1.361979] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[    1.362033] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[    1.362189] NET: Registered protocol family 1
[    1.362437] RPC: Registered named UNIX socket transport module.
[    1.362451] RPC: Registered udp transport module.
[    1.362463] RPC: Registered tcp transport module.
[    1.362475] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.362903] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    1.363641] futex hash table entries: 1024 (order: 5, 131072 bytes)
[    1.363756] audit: initializing netlink subsys (disabled)
[    1.363794] audit: type=2000 audit(1.352:1): initialized
[    1.364331] workingset: timestamp_bits=62 max_order=19 bucket_order=0
[    1.365041] NFS: Registering the id_resolver key type
[    1.365070] Key type id_resolver registered
[    1.365082] Key type id_legacy registered
[    1.365100] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.365130] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
[    1.369845] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    1.369870] io scheduler noop registered
[    1.369883] io scheduler deadline registered
[    1.369901] io scheduler cfq registered (default)
[    1.371196] Write failed gate address:1000f02
[    1.371334] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success
[    1.371485] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success
[    1.371630] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success
[    1.371795] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success
[    1.371957] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success
[    1.372114] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success
[    1.372272] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success
[    1.372416] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success
[    1.372884] xilinx-zynqmp-dma ffa80000.dma: ZynqMP DMA driver Probe success
[    1.373032] xilinx-zynqmp-dma ffa90000.dma: ZynqMP DMA driver Probe success
[    1.373180] xilinx-zynqmp-dma ffaa0000.dma: ZynqMP DMA driver Probe success
[    1.373327] xilinx-zynqmp-dma ffab0000.dma: ZynqMP DMA driver Probe success
[    1.373475] xilinx-zynqmp-dma ffac0000.dma: ZynqMP DMA driver Probe success
[    1.373623] xilinx-zynqmp-dma ffad0000.dma: ZynqMP DMA driver Probe success
[    1.373770] xilinx-zynqmp-dma ffae0000.dma: ZynqMP DMA driver Probe success
[    1.373917] xilinx-zynqmp-dma ffaf0000.dma: ZynqMP DMA driver Probe success
[    1.374032] zynqmp_pm firmware: Power management API v0.3
[    1.374138] xenfs: not registering filesystem on non-xen platform
[    1.410646] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.412379] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 40, base_baud = 6249999) is a xuartps
[    2.383492] console [ttyPS0] enabled
[    2.387601] ff010000.serial: ttyPS1 at MMIO 0xff010000 (irq = 41, base_baud = 6249999) is a xuartps
[    2.396785] [drm] Initialized
[    2.399950] Unable to detect cache hierarchy from DT for CPU 0
[    2.411152] brd: module loaded
[    2.417373] loop: module loaded
[    2.421505] ahci-ceva fd0c0000.ahci: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl platform mode
[    2.430400] ahci-ceva fd0c0000.ahci: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst
[    2.440950] scsi host0: ahci-ceva
[    2.444420] scsi host1: ahci-ceva
[    2.447807] ata1: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x100 irq 37
[    2.455656] ata2: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x180 irq 37
[    2.463720] mtdoops: mtd device (mtddev=name/number) must be supplied
[    2.472016] libphy: Fixed MDIO Bus: probed
[    2.477258] tun: Universal TUN/TAP device driver, 1.6
[    2.482245] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    2.488556] CAN device driver interface
[    2.493694] libphy: MACB_mii_bus: probed
[    2.499971] macb ff0e0000.ethernet eth0: Could not attach to PHY
[    2.540471] usbcore: registered new interface driver asix
[    2.545844] usbcore: registered new interface driver ax88179_178a
[    2.551902] usbcore: registered new interface driver cdc_ether
[    2.557715] usbcore: registered new interface driver net1080
[    2.563356] usbcore: registered new interface driver cdc_subset
[    2.569261] usbcore: registered new interface driver zaurus
[    2.574827] usbcore: registered new interface driver cdc_ncm
[    2.580919] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.587376] ehci-pci: EHCI PCI platform driver
[    2.592039] usbcore: registered new interface driver cdc_acm
[    2.597625] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    2.605643] usbcore: registered new interface driver uas
[    2.610942] usbcore: registered new interface driver usb-storage
[    2.617197] mousedev: PS/2 mouse device common for all mice
[    2.623134] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc0
[    2.630319] i2c /dev entries driver
[    2.634200] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 32
[    2.640518] pca954x 0-0070: registered 0 multiplexed busses for I2C mux pca9542
[    2.649077] Bluetooth: HCI UART driver ver 2.3
[    2.653449] Bluetooth: HCI UART protocol H4 registered
[    2.658565] Bluetooth: HCI UART protocol BCSP registered
[    2.663859] Bluetooth: HCI UART protocol LL registered
[    2.668980] Bluetooth: HCI UART protocol ATH3K registered
[    2.674362] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    2.680649] Bluetooth: HCI UART protocol Intel registered
[    2.686029] Bluetooth: HCI UART protocol Broadcom registered
[    2.691637] Bluetooth: HCI UART protocol QCA registered
[    2.696883] usbcore: registered new interface driver bcm203x
[    2.702520] usbcore: registered new interface driver bpa10x
[    2.708075] usbcore: registered new interface driver bfusb
[    2.713544] usbcore: registered new interface driver btusb
[    2.718979] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[    2.724675] usbcore: registered new interface driver ath3k
[    2.730229] EDAC MC: ECC not enabled
[    2.733862] EDAC DEVICE0: Giving out device to module edac controller cache_err: DEV edac (POLLED)
[    2.742909] EDAC DEVICE1: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
[    2.755516] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 1099999 KHz
[    2.763026] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 1199999 KHz
[    2.771891] sdhci: Secure Digital Host Controller Interface driver
[    2.777912] ata1: SATA link down (SStatus 0 SControl 330)
[    2.777953] ata2: SATA link down (SStatus 0 SControl 330)
[    2.788756] sdhci: Copyright(c) Pierre Ossman
[    2.793095] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.843723] mmc0: SDHCI controller on ff160000.sdhci [ff160000.sdhci] using ADMA 64-bit
[    2.899694] mmc1: SDHCI controller on ff170000.sdhci [ff170000.sdhci] using ADMA 64-bit
[    2.907994] ledtrig-cpu: registered to indicate activity on CPUs
[    2.914058] usbcore: registered new interface driver usbhid
[    2.919553] usbhid: USB HID core driver
[    2.925226] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
[    2.932549] pktgen: Packet Generator for packet performance testing. Version: 2.75
[    2.945364] Netfilter messages via NETLINK v0.30.
[    2.949483] mmc0: new HS200 MMC card at address 0001
[    2.949743] mmcblk0: mmc0:0001 Q2J55L 7.09 GiB
[    2.949844] mmcblk0boot0: mmc0:0001 Q2J55L partition 1 16.0 MiB
[    2.949940] mmcblk0boot1: mmc0:0001 Q2J55L partition 2 16.0 MiB
[    2.950031] mmcblk0rpmb: mmc0:0001 Q2J55L partition 3 4.00 MiB
[    2.950898]  mmcblk0: p1
[    2.970474] mmc1: new high speed SDHC card at address aaaa
[    2.970690] mmcblk1: mmc1:aaaa SL08G 7.40 GiB (ro)
[    2.971557]  mmcblk1: p1 p2
[    2.992736] ip_tables: (C) 2000-2006 Netfilter Core Team
[    2.998022] Initializing XFRM netlink socket
[    3.002281] NET: Registered protocol family 10
[    3.007086] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    3.012457] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    3.018693] NET: Registered protocol family 17
[    3.023072] NET: Registered protocol family 15
[    3.027498] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    3.040433] Ebtables v2.0 registered
[    3.044025] can: controller area network core (rev 20120528 abi 9)
[    3.050179] NET: Registered protocol family 29
[    3.054579] can: raw protocol (rev 20120528)
[    3.058822] can: broadcast manager protocol (rev 20161123 t)
[    3.064468] can: netlink gateway (rev 20130117) max_hops=1
[    3.070017] Bluetooth: RFCOMM TTY layer initialized
[    3.074826] Bluetooth: RFCOMM socket layer initialized
[    3.079949] Bluetooth: RFCOMM ver 1.11
[    3.083669] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    3.088978] Bluetooth: BNEP filters: protocol multicast
[    3.094180] Bluetooth: BNEP socket layer initialized
[    3.099124] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    3.105029] Bluetooth: HIDP socket layer initialized
[    3.110157] 9pnet: Installing 9P2000 support
[    3.114362] Key type dns_resolver registered
[    3.119103] registered taskstats version 1
[    3.123548] Btrfs loaded, crc32c=crc32c-generic
[    3.139496] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    3.144936] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    3.152823] xhci-hcd xhci-hcd.0.auto: hcc params 0x0238f625 hci version 0x100 quirks 0x00010010
[    3.161495] xhci-hcd xhci-hcd.0.auto: irq 218, io mem 0xfe200000
[    3.167571] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    3.174291] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.181499] usb usb1: Product: xHCI Host Controller
[    3.186350] usb usb1: Manufacturer: Linux 4.9.0-xilinx-v2017.2 xhci-hcd
[    3.192948] usb usb1: SerialNumber: xhci-hcd.0.auto
[    3.198151] hub 1-0:1.0: USB hub found
[    3.201851] hub 1-0:1.0: 1 port detected
[    3.205918] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    3.211332] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[    3.219020] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    3.227123] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    3.233834] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.241042] usb usb2: Product: xHCI Host Controller
[    3.245895] usb usb2: Manufacturer: Linux 4.9.0-xilinx-v2017.2 xhci-hcd
[    3.252493] usb usb2: SerialNumber: xhci-hcd.0.auto
[    3.257636] hub 2-0:1.0: USB hub found
[    3.261332] hub 2-0:1.0: 1 port detected
[    3.265617] rtc_zynqmp ffa60000.rtc: setting system clock to 1974-04-03 10:46:32 UTC (134217992)
[    3.274436] clk: Not disabling unused clocks
[    3.278798] ALSA device list:
[    3.281692]   No soundcards found.
[    3.285624] VFS: Cannot open root device "mmcblk0p2" or unknown-block(179,2): error -6
[    3.293489] Please append a correct "root=" boot option; here are the available partitions:
[    3.301818] 0100           65536 ram0 [    3.305347]  (driver?)
[    3.307699] 0101           65536 ram1 [    3.311566]  (driver?)
[    3.313921] 0102           65536 ram2 [    3.317474]  (driver?)
[    3.319824] 0103           65536 ram3 [    3.323371]  (driver?)
[    3.325727] 0104           65536 ram4 [    3.329278]  (driver?)
[    3.331624] 0105           65536 ram5 [    3.335181]  (driver?)
[    3.337531] 0106           65536 ram6 [    3.341083]  (driver?)
[    3.343429] 0107           65536 ram7 [    3.346985]  (driver?)
[    3.349337] 0108           65536 ram8 [    3.352889]  (driver?)
[    3.355234] 0109           65536 ram9 [    3.358791]  (driver?)
[    3.361141] 010a           65536 ram10 [    3.364780]  (driver?)
[    3.367126] 010b           65536 ram11 [    3.371394]  (driver?)
[    3.373746] 010c           65536 ram12 [    3.377383]  (driver?)
[    3.379735] 010d           65536 ram13 [    3.383368]  (driver?)
[    3.385723] 010e           65536 ram14 [    3.389362]  (driver?)
[    3.391712] 010f           65536 ram15 [    3.395346]  (driver?)
[    3.397706] b300         7438336 mmcblk0 [    3.401514]  driver: mmcblk
[    3.404300]   b301          250040 mmcblk0p1 00000000-01[    3.409413]
[    3.410891] b318            4096 mmcblk0rpmb [    3.415056]  (driver?)
[    3.417406] b310           16384 mmcblk0boot1 [    3.421652]  (driver?)
[    3.424003] b308           16384 mmcblk0boot0 [    3.428249]  (driver?)
[    3.430595] b320         7761920 mmcblk1 [    3.434411]  driver: mmcblk
[    3.437198]   b321          524288 mmcblk1p1 d1fdbe62-01[    3.442310]
[    3.443794]   b322         7233536 mmcblk1p2 d1fdbe62-02[    3.448907]
[    3.450385] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,2)
[    3.458815] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.9.0-xilinx-v2017.2 #1
[    3.465923] Hardware name: xlnx,zynqmp (DT)
[    3.470088] Call trace:
[    3.472526] [<ffffff8008088138>] dump_backtrace+0x0/0x198
[    3.477905] [<ffffff80080882e4>] show_stack+0x14/0x20
[    3.482939] [<ffffff80083de514>] dump_stack+0x94/0xb8
[    3.487974] [<ffffff800812e980>] panic+0x114/0x25c
[    3.492747] [<ffffff8008c110e8>] mount_block_root+0x198/0x270
[    3.498475] [<ffffff8008c113f8>] mount_root+0x11c/0x134
[    3.503682] [<ffffff8008c1157c>] prepare_namespace+0x16c/0x1b4
[    3.509499] [<ffffff8008c10d14>] kernel_init_freeable+0x1c0/0x1e0
[    3.515575] [<ffffff80089359a0>] kernel_init+0x10/0x100
[    3.520782] [<ffffff8008082e80>] ret_from_fork+0x10/0x50
[    3.526075] SMP: stopping secondary CPUs
[    3.529982] Kernel Offset: disabled
[    3.533452] Memory Limit: none
[    3.536493] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,2)
Any idea how to fix this?
Eth cable is not connected to my board, that's why the timeout in the output.
My goal is to get the CPU side working so that I can produce code/programs there. I'll get to FPGA later.
I'd like also to get advises for using CPU-side efficiently. Most of the tutorials and examples are for FPGA.
What framework or libraries can I use on the CPU-side? How to import and use those libraries?
I've seen some Qt examples but those are all for older versions of petalinux and vivado.
Has anyone used Qt on Ultrazed with 2017 version softwares?
I have used linux before but when I tried the arch linux I felt that I have never used linux...
imgignacio
Hi @waldemar,
your Linux system is not booting because the kernel cannot mount the rootfs.
The boot arguments are telling the kernel, that the rootfs is in the second partition of the device mmc 0 (I assume this is the SD card)
But it doesn't find this second partition there:
(Just to be sure, check that the SD card has the 2 partitions, but I assume this has properly done correctly)
In my opinion, the problem is that the SD card is being mounted as device mmc 1 and the flash as mmc 0, that's why the kernel is looking in the wrong place. So the solution would be to tell him to look on mmc 1. To test this, just follow these steps:
  1. Stop U-Boot when it says "Hit any key to stop autoboot".
  2. Copy this line in the terminal:
    setenv bootargs 'earlycon clk_ignore_unused root=/dev/mmcblk1p2 rw rootwait'
  3. Write on U-Boot:
    boot
Now it should boot.
Just another thing: U-Boot is booting the kernel from the Flash!! U-Boot shows you the mmc devices:
And then it indicates you that it is taking the kernel from flash:
Manufacturer ID: 13
OEM: 14e
Rd Block Len: 512
MMC version 5.0
High Capacity: Yes
Capacity: 7.1 GiB
Bus Width: 8-bit
reading image.ub
This should also be changed if you want to use your own kernel.
  • Check if the jumpers of your board are OK
  • If it doesn't change, check if Petalinux configuration indicates to boot from SD card.
If it keeps taking the kernel from flash, let me know and we will see how to change that by changing the configuration of U-Boot. But first let's look if the new bootargs make Linux boot ;)
Ignacio
Tags (3)
ibaie
Hi @waldemar
@imgignacio made great analysis of your issue so just following his comments should be enough to solve your doubts. I'm just replaying to an extra point to the analysis.
If you take a look to the mmc kernel bring up you can actually check how mmc0 refers to the eMMC device and mmc1 to the SD card which has actually two partitions as expected.
Ibai
Ibai
waldemar
Thank you for your replies @imgignacio and @ibaie.
I did as you instructed but the result is still the same. Jumpers/boot mode switch on the board is set to SD1 (OFF-ON-OFF-ON).
In Petalinux config the settings are boot image: primary sd, kernel image: primary sd, dtb image: primary sd, root filesystem: sd card.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2017.11.07 08:02:13 =~=~=~=~=~=~=~=~=~=~=~=
Release 2017.2   Nov  6 2017  -  21:21:28
NOTICE:  BL31: Built : 12:43:15, Nov  6 2017
U-Boot 2017.01 (Nov 06 2017 - 04:41:47 -0800) Xilinx ZynqMP ZCU102 revB
ready
DRAM:  2 GiB
EL Level:	EL2
Chip ID:	xczu3eg
In:    serial
Out:   serial
Err:   serial
Hit any key to stop autoboot:  4  0
ZynqMP> setenv bootargs 'earlycon clk_ignore_unused root=/dev/mmcblk1p2 rw rootwait'
ZynqMP> boot
Manufacturer ID: 13
OEM: 14e
Rd Block Len: 512
MMC version 5.0
High Capacity: Yes
Capacity: 7.1 GiB
Bus Width: 8-bit
reading image.ub
13269620 bytes read in 898 ms (14.1 MiB/s)
     Type:         Kernel Image
     OS:           Linux
     Hash algo:    sha1
     Hash value:   5543e0787e3f3d6b4011922bf83095ad61571d08
     Hash algo:    sha1
Starting kernel ...
[    0.000000] Linux version 4.9.0-xilinx-v2017.2 (vk@ubuntu) (gcc version 6.2.1 20161016 (Linaro GCC 6.2-2016.11) ) #1 SMP Mon Nov 6 04:30:15 PST 2017
[    0.000000] Kernel command line: earlycon clk_ignore_unused root=/dev/mmcblk1p2 rw rootwait
[    0.000000] Memory: 1920412K/2097152K available (9020K kernel code, 574K rwdata, 2780K rodata, 512K init, 394K bss, 45668K reserved, 131072K cma-reserved)
[    0.008263] Console: colour dummy device 80x25
[    0.012526] console [tty0] enabled
[    0.015889] bootconsole [cdns0] disabled
[    0.019813] pid_max: default: 32768 minimum: 301
[    0.020571] ASID allocator initialised with 65536 entries
[    0.021152] zynqmp_plat_init Power management API v0.3
[    0.021238] EFI services will not be available.
[    0.021695] Detected VIPT I-cache on CPU1
[    0.021725] CPU1: Booted secondary processor [410fd034]
[    0.022098] Detected VIPT I-cache on CPU2
[    0.022117] CPU2: Booted secondary processor [410fd034]
[    0.022478] Detected VIPT I-cache on CPU3
[    0.022496] CPU3: Booted secondary processor [410fd034]
[    0.022534] Brought up 4 CPUs
[    0.022569] SMP: Total of 4 processors activated.
[    0.022578] CPU features: detected feature: 32-bit EL0 Support
[    0.022588] CPU: All CPU(s) started at EL2
[    0.022606] alternatives: patching kernel code
[    0.023354] devtmpfs: initialized
[    0.027817] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.030821] xor: measuring software checksum speed
[    0.067871]    8regs     :  2111.000 MB/sec
[    0.107903]    8regs_prefetch:  1882.000 MB/sec
[    0.147938]    32regs    :  2594.000 MB/sec
[    0.187966]    32regs_prefetch:  2181.000 MB/sec
[    0.187979] xor: using function: 32regs (2594.000 MB/sec)
[    0.188794] NET: Registered protocol family 16
[    0.210254] cpuidle: using governor menu
[    0.210485] Failed to initialise IOMMU /amba/smmu@fd800000
[    0.210675] vdso: 2 pages (1 code @ ffffff8008957000, 1 data @ ffffff8008c94000)
[    0.210703] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.211354] DMA: preallocated 256 KiB pool for atomic allocations
[    0.236958] reset_zynqmp reset-controller: Xilinx zynqmp reset driver probed
[    0.237386] ARM CCI_400_r1 PMU driver probed
[    0.240835] zynqmp-pinctrl ff180000.pinctrl: zynqmp pinctrl initialized
[    0.267962] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.336197] raid6: int64x1  gen()   373 MB/s
[    0.404185] raid6: int64x1  xor()   405 MB/s
[    0.472260] raid6: int64x2  gen()   617 MB/s
[    0.540313] raid6: int64x2  xor()   549 MB/s
[    0.608345] raid6: int64x4  gen()   901 MB/s
[    0.676391] raid6: int64x4  xor()   677 MB/s
[    0.744471] raid6: int64x8  gen()  1050 MB/s
[    0.812524] raid6: int64x8  xor()   684 MB/s
[    0.880549] raid6: neonx1   gen()   661 MB/s
[    0.948613] raid6: neonx1   xor()   695 MB/s
[    1.016685] raid6: neonx2   gen()  1069 MB/s
[    1.084715] raid6: neonx2   xor()   948 MB/s
[    1.152771] raid6: neonx4   gen()  1379 MB/s
[    1.220787] raid6: neonx4   xor()  1083 MB/s
[    1.288860] raid6: neonx8   gen()  1454 MB/s
[    1.356897] raid6: neonx8   xor()  1119 MB/s
[    1.356909] raid6: using algorithm neonx8 gen() 1454 MB/s
[    1.356922] raid6: .... xor() 1119 MB/s, rmw enabled
[    1.356934] raid6: using intx1 recovery algorithm
[    1.357701] SCSI subsystem initialized
[    1.357928] usbcore: registered new interface driver usbfs
[    1.357976] usbcore: registered new interface driver hub
[    1.358027] usbcore: registered new device driver usb
[    1.358113] media: Linux media interface: v0.10
[    1.358151] Linux video capture interface: v2.00
[    1.358191] pps_core: LinuxPPS API ver. 1 registered
[    1.358204] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.358236] PTP clock support registered
[    1.358271] EDAC MC: Ver: 3.0.0
[    1.358576] FPGA manager framework
[    1.358630] Advanced Linux Sound Architecture Driver Initialized.
[    1.358983] Bluetooth: Core ver 2.22
[    1.359014] NET: Registered protocol family 31
[    1.359027] Bluetooth: HCI device and connection manager initialized
[    1.359046] Bluetooth: HCI socket layer initialized
[    1.359062] Bluetooth: L2CAP socket layer initialized
[    1.359092] Bluetooth: SCO socket layer initialized
[    1.359748] clocksource: Switched to clocksource arch_sys_counter
[    1.359838] VFS: Disk quotas dquot_6.6.0
[    1.359890] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.366591] NET: Registered protocol family 2
[    1.366995] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    1.367127] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[    1.367408] TCP: Hash tables configured (established 16384 bind 16384)
[    1.367488] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[    1.367542] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[    1.367694] NET: Registered protocol family 1
[    1.368063] RPC: Registered named UNIX socket transport module.
[    1.368077] RPC: Registered udp transport module.
[    1.368089] RPC: Registered tcp transport module.
[    1.368101] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.368536] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    1.369270] futex hash table entries: 1024 (order: 5, 131072 bytes)
[    1.369349] audit: initializing netlink subsys (disabled)
[    1.369385] audit: type=2000 audit(1.356:1): initialized
[    1.369921] workingset: timestamp_bits=62 max_order=19 bucket_order=0
[    1.370617] NFS: Registering the id_resolver key type
[    1.370643] Key type id_resolver registered
[    1.370655] Key type id_legacy registered
[    1.370673] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.370703] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
[    1.375535] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    1.375561] io scheduler noop registered
[    1.375573] io scheduler deadline registered
[    1.375591] io scheduler cfq registered (default)
[    1.377041] Write failed gate address:1000f02
[    1.377188] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success
[    1.377344] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success
[    1.377493] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success
[    1.377636] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success
[    1.377787] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success
[    1.377934] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success
[    1.378079] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success
[    1.378224] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success
[    1.378682] xilinx-zynqmp-dma ffa80000.dma: ZynqMP DMA driver Probe success
[    1.378830] xilinx-zynqmp-dma ffa90000.dma: ZynqMP DMA driver Probe success
[    1.378978] xilinx-zynqmp-dma ffaa0000.dma: ZynqMP DMA driver Probe success
[    1.379124] xilinx-zynqmp-dma ffab0000.dma: ZynqMP DMA driver Probe success
[    1.379277] xilinx-zynqmp-dma ffac0000.dma: ZynqMP DMA driver Probe success
[    1.379426] xilinx-zynqmp-dma ffad0000.dma: ZynqMP DMA driver Probe success
[    1.379573] xilinx-zynqmp-dma ffae0000.dma: ZynqMP DMA driver Probe success
[    1.379732] xilinx-zynqmp-dma ffaf0000.dma: ZynqMP DMA driver Probe success
[    1.379839] zynqmp_pm firmware: Power management API v0.3
[    1.379946] xenfs: not registering filesystem on non-xen platform
[    1.411365] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.413008] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 40, base_baud = 6249999) is a xuartps
[    2.384033] console [ttyPS0] enabled
[    2.388185] ff010000.serial: ttyPS1 at MMIO 0xff010000 (irq = 41, base_baud = 6249999) is a xuartps
[    2.397368] [drm] Initialized
[    2.400545] Unable to detect cache hierarchy from DT for CPU 0
[    2.411647] brd: module loaded
[    2.417888] loop: module loaded
[    2.421999] ahci-ceva fd0c0000.ahci: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl platform mode
[    2.430896] ahci-ceva fd0c0000.ahci: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst
[    2.441455] scsi host0: ahci-ceva
[    2.444931] scsi host1: ahci-ceva
[    2.448316] ata1: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x100 irq 37
[    2.456170] ata2: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x180 irq 37
[    2.464228] mtdoops: mtd device (mtddev=name/number) must be supplied
[    2.472517] libphy: Fixed MDIO Bus: probed
[    2.477726] tun: Universal TUN/TAP device driver, 1.6
[    2.482706] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    2.489012] CAN device driver interface
[    2.494155] libphy: MACB_mii_bus: probed
[    2.500434] macb ff0e0000.ethernet eth0: Could not attach to PHY
[    2.536513] usbcore: registered new interface driver asix
[    2.541887] usbcore: registered new interface driver ax88179_178a
[    2.547943] usbcore: registered new interface driver cdc_ether
[    2.553757] usbcore: registered new interface driver net1080
[    2.559398] usbcore: registered new interface driver cdc_subset
[    2.565302] usbcore: registered new interface driver zaurus
[    2.570869] usbcore: registered new interface driver cdc_ncm
[    2.576959] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.583409] ehci-pci: EHCI PCI platform driver
[    2.588073] usbcore: registered new interface driver cdc_acm
[    2.593659] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    2.601678] usbcore: registered new interface driver uas
[    2.606975] usbcore: registered new interface driver usb-storage
[    2.613237] mousedev: PS/2 mouse device common for all mice
[    2.619168] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc0
[    2.626357] i2c /dev entries driver
[    2.630233] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 32
[    2.636557] pca954x 0-0070: registered 0 multiplexed busses for I2C mux pca9542
[    2.645060] Bluetooth: HCI UART driver ver 2.3
[    2.649432] Bluetooth: HCI UART protocol H4 registered
[    2.654554] Bluetooth: HCI UART protocol BCSP registered
[    2.659843] Bluetooth: HCI UART protocol LL registered
[    2.664963] Bluetooth: HCI UART protocol ATH3K registered
[    2.670345] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    2.676632] Bluetooth: HCI UART protocol Intel registered
[    2.682012] Bluetooth: HCI UART protocol Broadcom registered
[    2.687620] Bluetooth: HCI UART protocol QCA registered
[    2.692865] usbcore: registered new interface driver bcm203x
[    2.698502] usbcore: registered new interface driver bpa10x
[    2.704057] usbcore: registered new interface driver bfusb
[    2.709526] usbcore: registered new interface driver btusb
[    2.714962] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[    2.720658] usbcore: registered new interface driver ath3k
[    2.726213] EDAC MC: ECC not enabled
[    2.729843] EDAC DEVICE0: Giving out device to module edac controller cache_err: DEV edac (POLLED)
[    2.738883] EDAC DEVICE1: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
[    2.751502] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 1099999 KHz
[    2.759018] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 1199999 KHz
[    2.767886] sdhci: Secure Digital Host Controller Interface driver
[    2.773987] sdhci: Copyright(c) Pierre Ossman
[    2.777995] ata1: SATA link down (SStatus 0 SControl 330)
[    2.778037] ata2: SATA link down (SStatus 0 SControl 330)
[    2.789088] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.839738] mmc0: SDHCI controller on ff160000.sdhci [ff160000.sdhci] using ADMA 64-bit
[    2.895736] mmc1: SDHCI controller on ff170000.sdhci [ff170000.sdhci] using ADMA 64-bit
[    2.904111] ledtrig-cpu: registered to indicate activity on CPUs
[    2.910169] usbcore: registered new interface driver usbhid
[    2.915666] usbhid: USB HID core driver
[    2.921853] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
[    2.928840] pktgen: Packet Generator for packet performance testing. Version: 2.75
[    2.936712] Netfilter messages via NETLINK v0.30.
[    2.941457] ip_tables: (C) 2000-2006 Netfilter Core Team
[    2.946748] Initializing XFRM netlink socket
[    2.946782] mmc0: new HS200 MMC card at address 0001
[    2.947044] mmcblk0: mmc0:0001 Q2J55L 7.09 GiB
[    2.947144] mmcblk0boot0: mmc0:0001 Q2J55L partition 1 16.0 MiB
[    2.947240] mmcblk0boot1: mmc0:0001 Q2J55L partition 2 16.0 MiB
[    2.947331] mmcblk0rpmb: mmc0:0001 Q2J55L partition 3 4.00 MiB
[    2.948198]  mmcblk0: p1
[    2.966394] mmc1: new high speed SDHC card at address aaaa
[    2.966612] mmcblk1: mmc1:aaaa SL08G 7.40 GiB (ro)
[    2.967463]  mmcblk1: p1 p2
[    2.993626] NET: Registered protocol family 10
[    2.998429] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    3.003804] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    3.010043] NET: Registered protocol family 17
[    3.014419] NET: Registered protocol family 15
[    3.018847] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    3.031784] Ebtables v2.0 registered
[    3.035366] can: controller area network core (rev 20120528 abi 9)
[    3.041526] NET: Registered protocol family 29
[    3.045918] can: raw protocol (rev 20120528)
[    3.050169] can: broadcast manager protocol (rev 20161123 t)
[    3.055815] can: netlink gateway (rev 20130117) max_hops=1
[    3.061339] Bluetooth: RFCOMM TTY layer initialized
[    3.066149] Bluetooth: RFCOMM socket layer initialized
[    3.071270] Bluetooth: RFCOMM ver 1.11
[    3.074997] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    3.080288] Bluetooth: BNEP filters: protocol multicast
[    3.085500] Bluetooth: BNEP socket layer initialized
[    3.090444] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    3.096349] Bluetooth: HIDP socket layer initialized
[    3.101476] 9pnet: Installing 9P2000 support
[    3.105684] Key type dns_resolver registered
[    3.110342] registered taskstats version 1
[    3.114777] Btrfs loaded, crc32c=crc32c-generic
[    3.130648] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    3.136084] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    3.143960] xhci-hcd xhci-hcd.0.auto: hcc params 0x0238f625 hci version 0x100 quirks 0x00010010
[    3.152629] xhci-hcd xhci-hcd.0.auto: irq 218, io mem 0xfe200000
[    3.158700] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    3.165417] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.172622] usb usb1: Product: xHCI Host Controller
[    3.177473] usb usb1: Manufacturer: Linux 4.9.0-xilinx-v2017.2 xhci-hcd
[    3.184070] usb usb1: SerialNumber: xhci-hcd.0.auto
[    3.189277] hub 1-0:1.0: USB hub found
[    3.192972] hub 1-0:1.0: 1 port detected
[    3.197040] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    3.202454] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[    3.210140] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    3.218244] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    3.224956] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.232164] usb usb2: Product: xHCI Host Controller
[    3.237017] usb usb2: Manufacturer: Linux 4.9.0-xilinx-v2017.2 xhci-hcd
[    3.243615] usb usb2: SerialNumber: xhci-hcd.0.auto
[    3.248766] hub 2-0:1.0: USB hub found
[    3.252463] hub 2-0:1.0: 1 port detected
[    3.256751] rtc_zynqmp ffa60000.rtc: setting system clock to 1970-01-01 00:01:25 UTC (85)
[    3.264969] clk: Not disabling unused clocks
[    3.269330] ALSA device list:
[    3.272223]   No soundcards found.
[    3.276171] VFS: Cannot open root device "mmcblk1p2" or unknown-block(179,34): error -30
[    3.284205] Please append a correct "root=" boot option; here are the available partitions:
[    3.292526] 0100           65536 ram0 [    3.296064]  (driver?)
[    3.298411] 0101           65536 ram1 [    3.302305]  (driver?)
[    3.304656] 0102           65536 ram2 [    3.308208]  (driver?)
[    3.310554] 0103           65536 ram3 [    3.314109]  (driver?)
[    3.316462] 0104           65536 ram4 [    3.320012]  (driver?)
[    3.322359] 0105           65536 ram5 [    3.325916]  (driver?)
[    3.328265] 0106           65536 ram6 [    3.331818]  (driver?)
[    3.334164] 0107           65536 ram7 [    3.337719]  (driver?)
[    3.340072] 0108           65536 ram8 [    3.343617]  (driver?)
[    3.345973] 0109           65536 ram9 [    3.349525]  (driver?)
[    3.351877] 010a           65536 ram10 [    3.355509]  (driver?)
[    3.357866] 010b           65536 ram11 [    3.361503]  (driver?)
[    3.363855] 010c           65536 ram12 [    3.367488]  (driver?)
[    3.369844] 010d           65536 ram13 [    3.373482]  (driver?)
[    3.375833] 010e           65536 ram14 [    3.379466]  (driver?)
[    3.381823] 010f           65536 ram15 [    3.385460]  (driver?)
[    3.387815] b300         7438336 mmcblk0 [    3.391619]  driver: mmcblk
[    3.394409]   b301          250040 mmcblk0p1 00000000-01[    3.399522]
[    3.401005] b318            4096 mmcblk0rpmb [    3.405165]  (driver?)
[    3.407511] b310           16384 mmcblk0boot1 [    3.411762]  (driver?)
[    3.414107] b308           16384 mmcblk0boot0 [    3.418358]  (driver?)
[    3.420709] b320         7761920 mmcblk1 [    3.424521]  driver: mmcblk
[    3.427302]   b321          524288 mmcblk1p1 d1fdbe62-01[    3.432420]
[    3.433898]   b322         7233536 mmcblk1p2 d1fdbe62-02[    3.439018]
[    3.440499] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,34)
[    3.449011] CPU: 2 PID: 1 Comm: swapper/0 Not tainted 4.9.0-xilinx-v2017.2 #1
[    3.456119] Hardware name: xlnx,zynqmp (DT)
[    3.460284] Call trace:
[    3.462722] [<ffffff8008088138>] dump_backtrace+0x0/0x198
[    3.468101] [<ffffff80080882e4>] show_stack+0x14/0x20
[    3.473135] [<ffffff80083de514>] dump_stack+0x94/0xb8
[    3.478170] [<ffffff800812e980>] panic+0x114/0x25c
[    3.482943] [<ffffff8008c110e8>] mount_block_root+0x198/0x270
[    3.488671] [<ffffff8008c113f8>] mount_root+0x11c/0x134
[    3.493878] [<ffffff8008c1157c>] prepare_namespace+0x16c/0x1b4
[    3.499695] [<ffffff8008c10d14>] kernel_init_freeable+0x1c0/0x1e0
[    3.505771] [<ffffff80089359a0>] kernel_init+0x10/0x100
[    3.510979] [<ffffff8008082e80>] ret_from_fork+0x10/0x50
[    3.516271] SMP: stopping secondary CPUs
[    3.520178] Kernel Offset: disabled
[    3.523648] Memory Limit: none
[    3.526690] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,34)
Valtteri
imgignacio
Hi @waldemar,
the kernel still cannot mount the rootfs, but now the error is different (-30). Your kernel and device tree are still being loaded from the eMMC. That means, they are not the ones that you created with Petalinux:
ZynqMP> boot
Manufacturer ID: 13
OEM: 14e
Rd Block Len: 512
MMC version 5.0
Could you tell me which files you have on the first partition on the SD so that I can help you booting your kernel and device tree from there?
I think it makes sense to first boot your actual kernel and device tree and then see why it cannot mount the roofs.
Ignacio
waldemar
Hi and thanks for reply @imgignacio.
The files on the BOOT-section of sd-card are:
-rw-r--r-- 1 vk vk 24608 Nov 6 04:43 bl31.bin
-rw-r--r-- 1 vk vk 95064 Nov 6 04:43 bl31.elf
-rw-rw-r-- 1 vk vk 6435136 Nov 6 23:59 BOOT.BIN
-rw-r--r-- 1 vk vk 5568788 Nov 6 03:53 design_1_wrapper.bit
-rw-r--r-- 1 vk vk 13236736 Nov 6 04:34 Image
-rw-r--r-- 1 vk vk 13269620 Nov 6 21:24 image.ub
-rw-r--r-- 1 vk vk 112224 Nov 6 21:22 pmufw.elf
-rw-r--r-- 1 vk vk 8901787 Nov 6 21:24 rootfs.cpio.gz
-rw-r--r-- 1 vk vk 67108864 Nov 6 21:24 rootfs.ext3
-rw-r--r-- 1 vk vk 67108864 Nov 6 21:24 rootfs.ext4
-rw-r--r-- 1 vk vk 8966871 Nov 6 21:24 rootfs.ext4.gz
-rw-r--r-- 1 vk vk 31577 Nov 6 04:41 system.dtb
-rw-r--r-- 1 vk vk 3028339 Nov 6 04:34 System.map.linux
-rw-r--r-- 1 vk vk 602560 Nov 6 04:43 u-boot.bin
-rw-r--r-- 1 vk vk 668888 Nov 6 04:43 u-boot.elf
-rw-r--r-- 1 vk vk 192370560 Nov 6 04:34 vmlinux
-rw-r--r-- 1 vk vk 147848 Nov 6 21:22 zynqmp_fsbl.elf
This is the content of the ptlnx-project-folder/images/linux
Regards, Valtteri
imgignacio
Hi @waldemar,
thanks for the info! Could you try stopping the U-Boot autoboot timeout and inserting these commands? The purpose is to load kernel + device tree from your SD:
fatload mmc 1 0x3000000 image.ub
bootm 0x3000000
Could you post the output?
Ignacio
waldemar
@imgignacio
Here is the output:
ready
DRAM:  2 GiB
EL Level:	EL2
Chip ID:	xczu3eg
In:    serial
Out:   serial
Err:   serial
ZynqMP> fatload mmc 1 0x3000000 image.ub
reading image.ub
ZynqMP> bootm 0x3000000
## Loading kernel from FIT Image at 03000000 ...
     Type:         Kernel Image
     Data Start:   0x030000d8
     OS:           Linux
     Hash algo:    sha1
## Loading fdt from FIT Image at 03000000 ...
     Data Start:   0x03c9fbd0
     Hash algo:    sha1
   Booting using the fdt blob at 0x3c9fbd0
Starting kernel ...
[    0.008261] Console: colour dummy device 80x25
[    0.012516] console [tty0] enabled
[    0.015880] bootconsole [cdns0] disabled
[    0.019790] Calibrating delay loop (skipped), value calculated using timer frequency.. 199.99 BogoMIPS (lpj=399996)
[    0.019807] pid_max: default: 32768 minimum: 301
[    0.019920] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.019931] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.020564] ASID allocator initialised with 65536 entries
[    0.021145] zynqmp_plat_init Power management API v0.3
[    0.021233] EFI services will not be available.
[    0.021690] Detected VIPT I-cache on CPU1
[    0.021720] CPU1: Booted secondary processor [410fd034]
[    0.022472] Detected VIPT I-cache on CPU3
[    0.022491] CPU3: Booted secondary processor [410fd034]
[    0.022563] SMP: Total of 4 processors activated.
[    0.022572] CPU features: detected feature: 32-bit EL0 Support
[    0.023344] devtmpfs: initialized
[    0.027821] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.030831] xor: measuring software checksum speed
[    0.067865]    8regs     :  2111.000 MB/sec
[    0.107895]    8regs_prefetch:  1882.000 MB/sec
[    0.147931]    32regs    :  2594.000 MB/sec
[    0.187958]    32regs_prefetch:  2180.000 MB/sec
[    0.187971] xor: using function: 32regs (2594.000 MB/sec)
[    0.188073] pinctrl core: initialized pinctrl subsystem
[    0.188795] NET: Registered protocol family 16
[    0.210488] Failed to initialise IOMMU /amba/smmu@fd800000
[    0.210680] vdso: 2 pages (1 code @ ffffff8008957000, 1 data @ ffffff8008c94000)
[    0.210707] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.211341] DMA: preallocated 256 KiB pool for atomic allocations
[    0.236858] reset_zynqmp reset-controller: Xilinx zynqmp reset driver probed
[    0.237275] ARM CCI_400_r1 PMU driver probed
[    0.240723] zynqmp-pinctrl ff180000.pinctrl: zynqmp pinctrl initialized
[    0.266685] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.332237] raid6: int64x1  gen()   373 MB/s
[    0.400232] raid6: int64x1  xor()   405 MB/s
[    0.468271] raid6: int64x2  gen()   617 MB/s
[    0.536315] raid6: int64x2  xor()   549 MB/s
[    0.604334] raid6: int64x4  gen()   901 MB/s
[    0.672389] raid6: int64x4  xor()   677 MB/s
[    0.808512] raid6: int64x8  xor()   684 MB/s
[    0.876563] raid6: neonx1   gen()   662 MB/s
[    0.944574] raid6: neonx1   xor()   695 MB/s
[    1.012679] raid6: neonx2   gen()  1069 MB/s
[    1.080701] raid6: neonx2   xor()   949 MB/s
[    1.148749] raid6: neonx4   gen()  1379 MB/s
[    1.216783] raid6: neonx4   xor()  1083 MB/s
[    1.284863] raid6: neonx8   gen()  1454 MB/s
[    1.352891] raid6: neonx8   xor()  1119 MB/s
[    1.352904] raid6: using algorithm neonx8 gen() 1454 MB/s
[    1.352916] raid6: .... xor() 1119 MB/s, rmw enabled
[    1.352929] raid6: using intx1 recovery algorithm
[    1.353701] SCSI subsystem initialized
[    1.353926] usbcore: registered new interface driver usbfs
[    1.353973] usbcore: registered new interface driver hub
[    1.354025] usbcore: registered new device driver usb
[    1.354109] media: Linux media interface: v0.10
[    1.354147] Linux video capture interface: v2.00
[    1.354186] pps_core: LinuxPPS API ver. 1 registered
[    1.354199] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.354230] PTP clock support registered
[    1.354266] EDAC MC: Ver: 3.0.0
[    1.354588] FPGA manager framework
[    1.354640] Advanced Linux Sound Architecture Driver Initialized.
[    1.354981] Bluetooth: Core ver 2.22
[    1.355013] NET: Registered protocol family 31
[    1.355025] Bluetooth: HCI device and connection manager initialized
[    1.355044] Bluetooth: HCI socket layer initialized
[    1.355060] Bluetooth: L2CAP socket layer initialized
[    1.355091] Bluetooth: SCO socket layer initialized
[    1.355734] clocksource: Switched to clocksource arch_sys_counter
[    1.355839] VFS: Disk quotas dquot_6.6.0
[    1.355890] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.362606] NET: Registered protocol family 2
[    1.363008] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    1.363142] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[    1.363430] TCP: Hash tables configured (established 16384 bind 16384)
[    1.363506] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[    1.363560] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[    1.363715] NET: Registered protocol family 1
[    1.364024] RPC: Registered named UNIX socket transport module.
[    1.364039] RPC: Registered udp transport module.
[    1.364051] RPC: Registered tcp transport module.
[    1.364063] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.364498] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    1.365249] futex hash table entries: 1024 (order: 5, 131072 bytes)
[    1.365331] audit: initializing netlink subsys (disabled)
[    1.365368] audit: type=2000 audit(1.352:1): initialized
[    1.365906] workingset: timestamp_bits=62 max_order=19 bucket_order=0
[    1.366617] NFS: Registering the id_resolver key type
[    1.366648] Key type id_resolver registered
[    1.366660] Key type id_legacy registered
[    1.366678] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.366707] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
[    1.371500] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    1.371525] io scheduler noop registered
[    1.371538] io scheduler deadline registered
[    1.371556] io scheduler cfq registered (default)
[    1.372896] Write failed gate address:1000f02
[    1.373039] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success
[    1.373197] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success
[    1.373341] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success
[    1.373491] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success
[    1.373639] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success
[    1.373785] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success
[    1.373929] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success
[    1.374076] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success
[    1.374534] xilinx-zynqmp-dma ffa80000.dma: ZynqMP DMA driver Probe success
[    1.374681] xilinx-zynqmp-dma ffa90000.dma: ZynqMP DMA driver Probe success
[    1.374826] xilinx-zynqmp-dma ffaa0000.dma: ZynqMP DMA driver Probe success
[    1.374982] xilinx-zynqmp-dma ffab0000.dma: ZynqMP DMA driver Probe success
[    1.375130] xilinx-zynqmp-dma ffac0000.dma: ZynqMP DMA driver Probe success
[    1.375277] xilinx-zynqmp-dma ffad0000.dma: ZynqMP DMA driver Probe success
[    1.375422] xilinx-zynqmp-dma ffae0000.dma: ZynqMP DMA driver Probe success
[    1.375570] xilinx-zynqmp-dma ffaf0000.dma: ZynqMP DMA driver Probe success
[    1.375676] zynqmp_pm firmware: Power management API v0.3
[    1.375910] xenfs: not registering filesystem on non-xen platform
[    1.410207] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.411829] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 40, base_baud = 6249999) is a xuartps
[    2.382850] console [ttyPS0] enabled
[    2.386945] ff010000.serial: ttyPS1 at MMIO 0xff010000 (irq = 41, base_baud = 6249999) is a xuartps
[    2.396130] [drm] Initialized
[    2.399278] Unable to detect cache hierarchy from DT for CPU 0
[    2.410407] brd: module loaded
[    2.416627] loop: module loaded
[    2.420758] ahci-ceva fd0c0000.ahci: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl platform mode
[    2.429654] ahci-ceva fd0c0000.ahci: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst
[    2.440218] scsi host0: ahci-ceva
[    2.443675] scsi host1: ahci-ceva
[    2.447062] ata1: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x100 irq 37
[    2.454914] ata2: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x180 irq 37
[    2.462956] mtdoops: mtd device (mtddev=name/number) must be supplied
[    2.471213] libphy: Fixed MDIO Bus: probed
[    2.476466] tun: Universal TUN/TAP device driver, 1.6
[    2.481451] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    2.487768] CAN device driver interface
[    2.492920] libphy: MACB_mii_bus: probed
[    2.499187] macb ff0e0000.ethernet eth0: Could not attach to PHY
[    2.544521] usbcore: registered new interface driver asix
[    2.549898] usbcore: registered new interface driver ax88179_178a
[    2.555953] usbcore: registered new interface driver cdc_ether
[    2.561768] usbcore: registered new interface driver net1080
[    2.567410] usbcore: registered new interface driver cdc_subset
[    2.573311] usbcore: registered new interface driver zaurus
[    2.578879] usbcore: registered new interface driver cdc_ncm
[    2.584972] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.591428] ehci-pci: EHCI PCI platform driver
[    2.596101] usbcore: registered new interface driver cdc_acm
[    2.601687] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    2.609704] usbcore: registered new interface driver uas
[    2.615004] usbcore: registered new interface driver usb-storage
[    2.621258] mousedev: PS/2 mouse device common for all mice
[    2.627181] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc0
[    2.634362] i2c /dev entries driver
[    2.638242] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 32
[    2.644563] pca954x 0-0070: registered 0 multiplexed busses for I2C mux pca9542
[    2.653070] Bluetooth: HCI UART driver ver 2.3
[    2.657443] Bluetooth: HCI UART protocol H4 registered
[    2.662557] Bluetooth: HCI UART protocol BCSP registered
[    2.667851] Bluetooth: HCI UART protocol LL registered
[    2.672973] Bluetooth: HCI UART protocol ATH3K registered
[    2.678355] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    2.684642] Bluetooth: HCI UART protocol Intel registered
[    2.690022] Bluetooth: HCI UART protocol Broadcom registered
[    2.695630] Bluetooth: HCI UART protocol QCA registered
[    2.700875] usbcore: registered new interface driver bcm203x
[    2.706513] usbcore: registered new interface driver bpa10x
[    2.712068] usbcore: registered new interface driver bfusb
[    2.717535] usbcore: registered new interface driver btusb
[    2.722972] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[    2.728668] usbcore: registered new interface driver ath3k
[    2.734223] EDAC MC: ECC not enabled
[    2.737855] EDAC DEVICE0: Giving out device to module edac controller cache_err: DEV edac (POLLED)
[    2.746903] EDAC DEVICE1: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
[    2.759513] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 1099999 KHz
[    2.767028] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 1199999 KHz
[    2.775902] sdhci: Secure Digital Host Controller Interface driver
[    2.776866] ata2: SATA link down (SStatus 0 SControl 330)
[    2.776896] ata1: SATA link down (SStatus 0 SControl 330)
[    2.792767] sdhci: Copyright(c) Pierre Ossman
[    2.797105] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.847743] mmc0: SDHCI controller on ff160000.sdhci [ff160000.sdhci] using ADMA 64-bit
[    2.907743] mmc1: SDHCI controller on ff170000.sdhci [ff170000.sdhci] using ADMA 64-bit
[    2.916063] ledtrig-cpu: registered to indicate activity on CPUs
[    2.922142] usbcore: registered new interface driver usbhid
[    2.927640] usbhid: USB HID core driver
[    2.933309] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
[    2.940267] pktgen: Packet Generator for packet performance testing. Version: 2.75
[    2.948204] Netfilter messages via NETLINK v0.30.
[    2.952952] ip_tables: (C) 2000-2006 Netfilter Core Team
[    2.958177] mmc0: new HS200 MMC card at address 0001
[    2.958442] mmcblk0: mmc0:0001 Q2J55L 7.09 GiB
[    2.958543] mmcblk0boot0: mmc0:0001 Q2J55L partition 1 16.0 MiB
[    2.958637] mmcblk0boot1: mmc0:0001 Q2J55L partition 2 16.0 MiB
[    2.958734] mmcblk0rpmb: mmc0:0001 Q2J55L partition 3 4.00 MiB
[    2.959572]  mmcblk0: p1
[    2.978774] mmc1: new high speed SDHC card at address aaaa
[    2.978992] mmcblk1: mmc1:aaaa SL08G 7.40 GiB (ro)
[    2.979861]  mmcblk1: p1 p2
[    3.000849] Initializing XFRM netlink socket
[    3.005122] NET: Registered protocol family 10
[    3.009928] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    3.015305] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    3.021542] NET: Registered protocol family 17
[    3.025917] NET: Registered protocol family 15
[    3.030345] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    3.043276] Ebtables v2.0 registered
[    3.046867] can: controller area network core (rev 20120528 abi 9)
[    3.053033] NET: Registered protocol family 29
[    3.057418] can: raw protocol (rev 20120528)
[    3.061669] can: broadcast manager protocol (rev 20161123 t)
[    3.067313] can: netlink gateway (rev 20130117) max_hops=1
[    3.072850] Bluetooth: RFCOMM TTY layer initialized
[    3.077691] Bluetooth: RFCOMM socket layer initialized
[    3.082778] Bluetooth: RFCOMM ver 1.11
[    3.086505] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    3.091797] Bluetooth: BNEP filters: protocol multicast
[    3.097008] Bluetooth: BNEP socket layer initialized
[    3.101952] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    3.107858] Bluetooth: HIDP socket layer initialized
[    3.112982] 9pnet: Installing 9P2000 support
[    3.117192] Key type dns_resolver registered
[    3.121869] registered taskstats version 1
[    3.126305] Btrfs loaded, crc32c=crc32c-generic
[    3.142193] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    3.147642] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    3.155513] xhci-hcd xhci-hcd.0.auto: hcc params 0x0238f625 hci version 0x100 quirks 0x00010010
[    3.164185] xhci-hcd xhci-hcd.0.auto: irq 218, io mem 0xfe200000
[    3.170258] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    3.176978] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.184183] usb usb1: Product: xHCI Host Controller
[    3.189034] usb usb1: Manufacturer: Linux 4.9.0-xilinx-v2017.2 xhci-hcd
[    3.195630] usb usb1: SerialNumber: xhci-hcd.0.auto
[    3.200846] hub 1-0:1.0: USB hub found
[    3.204541] hub 1-0:1.0: 1 port detected
[    3.208611] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    3.214031] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[    3.221715] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    3.229821] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    3.236533] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.243741] usb usb2: Product: xHCI Host Controller
[    3.248595] usb usb2: Manufacturer: Linux 4.9.0-xilinx-v2017.2 xhci-hcd
[    3.255191] usb usb2: SerialNumber: xhci-hcd.0.auto
[    3.260334] hub 2-0:1.0: USB hub found
[    3.264033] hub 2-0:1.0: 1 port detected
[    3.268318] rtc_zynqmp ffa60000.rtc: setting system clock to 1970-01-01 00:00:12 UTC (12)
[    3.276527] clk: Not disabling unused clocks
[    3.280889] ALSA device list:
[    3.283781]   No soundcards found.
[    3.287753] VFS: Cannot open root device "mmcblk1p2" or unknown-block(179,34): error -30
[    3.295778] Please append a correct "root=" boot option; here are the available partitions:
[    3.304117] 0100           65536 ram0 [    3.307645]  (driver?)
[    3.310004] 0101           65536 ram1 [    3.313553]  (driver?)
[    3.315905] 0102           65536 ram2 [    3.319450]  (driver?)
[    3.321806] 0103           65536 ram3 [    3.325358]  (driver?)
[    3.327703] 0104           65536 ram4 [    3.331259]  (driver?)
[    3.333611] 0105           65536 ram5 [    3.337162]  (driver?)
[    3.339508] 0106           65536 ram6 [    3.343065]  (driver?)
[    3.345415] 0107           65536 ram7 [    3.348967]  (driver?)
[    3.351313] 0108           65536 ram8 [    3.354869]  (driver?)
[    3.357221] 0109           65536 ram9 [    3.360771]  (driver?)
[    3.363118] 010a           65536 ram10 [    3.366762]  (driver?)
[    3.369112] 010b           65536 ram11 [    3.372751]  (driver?)
[    3.375097] 010c           65536 ram12 [    3.378741]  (driver?)
[    3.381092] 010d           65536 ram13 [    3.384729]  (driver?)
[    3.387075] 010e           65536 ram14 [    3.390719]  (driver?)
[    3.393069] 010f           65536 ram15 [    3.396708]  (driver?)
[    3.399056] b300         7438336 mmcblk0 [    3.402871]  driver: mmcblk
[    3.405658]   b301          250040 mmcblk0p1 00000000-01[    3.410770]
[    3.412253] b318            4096 mmcblk0rpmb [    3.416411]  (driver?)
[    3.418757] b310           16384 mmcblk0boot1 [    3.423009]  (driver?)
[    3.425359] b308           16384 mmcblk0boot0 [    3.429606]  (driver?)
[    3.431956] b320         7761920 mmcblk1 [    3.435769]  driver: mmcblk
[    3.438548]   b321          524288 mmcblk1p1 d1fdbe62-01[    3.443667]
[    3.445151]   b322         7233536 mmcblk1p2 d1fdbe62-02[    3.450264]
[    3.451747] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,34)
[    3.460259] CPU: 3 PID: 1 Comm: swapper/0 Not tainted 4.9.0-xilinx-v2017.2 #1
[    3.467366] Hardware name: xlnx,zynqmp (DT)
[    3.471531] Call trace:
[    3.473968] [<ffffff8008088138>] dump_backtrace+0x0/0x198
[    3.479347] [<ffffff80080882e4>] show_stack+0x14/0x20
[    3.484382] [<ffffff80083de514>] dump_stack+0x94/0xb8
[    3.489417] [<ffffff800812e980>] panic+0x114/0x25c
[    3.494190] [<ffffff8008c110e8>] mount_block_root+0x198/0x270
[    3.499917] [<ffffff8008c113f8>] mount_root+0x11c/0x134
[    3.505125] [<ffffff8008c1157c>] prepare_namespace+0x16c/0x1b4
[    3.510942] [<ffffff8008c10d14>] kernel_init_freeable+0x1c0/0x1e0
[    3.517018] [<ffffff80089359a0>] kernel_init+0x10/0x100
[    3.522225] [<ffffff8008082e80>] ret_from_fork+0x10/0x50
[    3.527518] SMP: stopping secondary CPUs
[    3.531426] Kernel Offset: disabled
[    3.534895] Memory Limit: none
[    3.537937] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,34)
Regards, Valtteri
imgignacio
Hi @waldemar,
the kernel is booting OK but it's not being able to mount the rootfs... Let's check if the rootfs is there and if there is any problem with the device-tree regarding the SD card:
  1. Could you check if the 2nd partition of your SD is actually ext4? Can you "ls" it to see what it contains?
  2. Could you attach the file system.dtb of your 1st SD partition?
I suppose point 1 is going to be OK. Regarding point 2, it could be that a parameter for the SD driver is missing in the device tree.
Ignacio
waldemar
@imgignacio
The file system and content of 2nd partition of sd card:
vk@ubuntu:~$ blkid /dev/sde2
/dev/sde2: LABEL="rootfs" UUID="b12861bf-72ec-49ca-960f-c2466cc86d2f" TYPE="ext4" PARTUUID="80cf2e1c-02"
vk@ubuntu:~$ ls -l /media/vk/rootfs/
total 88
drwxr-xr-x  2 root root  4096 Jun 19 07:04 bin
drwxr-xr-x  3 root root  4096 Jun 19 07:04 boot
drwxr-xr-x  4 root root  4096 Jun 19 07:02 dev
drwxr-xr-x 86 root root  4096 Jun 19 07:04 etc
drwxr-xr-x  3 root root  4096 Jun 19 07:04 home
drwxr-xr-x 13 root root  4096 Jun 19 07:00 lib
drwx------  2 root root 16384 Nov  7 07:34 lost+found
drwxr-xr-x  2 root root  4096 Jun 19 06:46 media
drwxr-xr-x  2 root root  4096 Jun 19 06:46 mnt
drwxr-xr-x  4 root root  4096 Jun 19 07:04 opt
drwxr-xr-x  2 root root  4096 Apr 12  2016 proc
drwx------  2 root root  4096 Jun 19 06:46 root
drwxr-xr-x  2 root root  4096 Feb  5  2016 run
drwxr-xr-x  2 root root  4096 Jun 19 07:04 sbin
drwxr-xr-x  2 root root  4096 Jun 19 06:46 srv
drwxr-xr-x  2 root root  4096 Feb  5  2016 sys
drwxrwxrwt  2 root root  4096 Jun 19 07:04 tmp
drwxr-xr-x 10 root root  4096 Jun 19 06:46 usr
drwxr-xr-x 12 root root  4096 Jun 19 06:49 var
Regards, Valtteri
imgignacio
Hi @waldemar,
your device tree seems ok. What surprises me is that, even though you are introducing the U-Boot commands to load from the SD, it's loading exactly the same kernel (and possibly device-tree) as before... (the ones on eMMC).
What happens if you rename temporarily the "image.ub" file of the first partition of the SD to, for example "image.ub_NO"?
  1. After renaming, does the board boot without interrupting u-boot?
  2. After renaming, does the board boot interrupting U-Boot with the last commands I posted?
Could you save the logs and attach them?
After testing, don't forget to rename the "image.ub_NO" to its original name.
Ignacio
waldemar
 @imgignacio
The output with renamed image.ub:
** Unable to read file image.ub **
and with bootargs command
reading image.ub
Wrong Image Format for bootm command
ERROR: can't get kernel image!
ZynqMP>
Regards, Valtteri
imgignacio
Hi @waldemar,
ok, so it's loading your kernel + device tree...
I cannot understand why the kernel is not able to load the rootfs... In this situation, I would probably create a version with a ramdisk and once it booted I would check if the SD card works properly on Linux... I'm sorry that I cannot contribute with more ideas. If I think of any other possible solution, I will let you know.
Ignacio
waldemar
@imgignacio thank you for your effort with the problem.
I got something solved and got Ubuntu started.
There were an option "Device node SD device" in petalinux-config that I changed from /dev/mmcblk0p2 to /dev/mmcblk1p2.
This didn't solve the problem and the same error messages appeared but maybe that has something to do with this.
Then I entered commands:
setenv bootargs root=/dev/mmcblk1p2 rw rootwait rootfstype=ext4 rootdelay=5
bootm 0x3000000
and still no luck.
Then I saw somewhere a similar commands with ro not rw parameters and then Ubuntu started as I replaced that parameter.
So now I can start Ubuntu but it's in read only mode and I get errors:
-bash: cannot create temp file for here-document: Read-only file system
Some progress but still not running like it should.
waldemar
And it seems that I got this thing solved by editing ptlnx-prjct/project-spec/meta-user/recipes-bsp/device-tree/filessystem-user.dtsi.
I added line
disable-wp;
to sdhci0.
Then configured, built and packaged the project and it worked.
imgignacio
Hi @waldemar,
nice to hear that you got it working! Thanks for sharing it!
Ignacio
konze
I followed all the instructions and could reproduce errors. I solved it by adding
disable-wp;
to sdhci1 instead of sdhci0 (which I found here: http://www.zedboard.org/content/ultrazed-iocc-sd-card-ro)
HanShu
Hi konze !,I have  a same question and I solved it from here,thank you !
hosseinbeheshti
I have got the same problem. My problem arises because of an incomplete copy of the RootFS file in Linux.
use sync after your copy.
Hebi
where did you entered the commands?
system-user.dtsi? or somewhere else?
