raghuram1a
Bit file generation for fpga of ZCU104 ZYNQ Board and programming the PL
I want to program the PL of ZCU104 ZYNQ board from Petalinux running on board and test the PL from PS using sample application and also how to generate .bit file from Petalinux build   to program FPGA of board and run the application which would accelerate the FPGA(PL) from PS of the board. Couls anyone help me steps to proceed above points.
Raghuram
raghuram1a
Hi ALL,
Could anyone help me on this question . I will be thankful to them.
regards,
Raghuram
glena
Look in UG1144
stephenm
You can use the fpga manager to prog the PL in Linux:
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842056/FPGA+Manager+ZCU102
raghuram1a
Hi Stephen,
Thanks for your reply I will try with this steps.
Raghuram
