Boot Image from Jtag
SDK 2014.1
Petalinux 2013.10
zc702 board
I want to verify that the xmd console can be used for booting a full image through Jtag?
The steps that i've come accross so far in my searching to do this is as follows:
1) connect arm hw
2) fpga -f top.bit
3) source ps7_init.tcl
4) ps7_init
5) ps7_post_config
6) dow u-boot.elf
7) target 64
8) con
9) dow -data zImage 0x8000
10) dow -data devicetree 0x1000000
Unfortunatly when i get to step 9 it fails and returns the following error:
RUNNING> XMD% dow -data zImage 0x8000
ERROR: Cannot read from target
    AP transaction timeout: ACK = 0x01, expected=0x02)
XMD%
Could someone help me understand what steps are necessary to load a full image. I tried to execute my image.elf file that is created, and that also fails. Generally when i load the same image through a sd card i just include the boot.bin and image.ub files to load everything. Is there a way to just load those 2 files here to do the same thing?
Thanks!
Re: Boot Image from Jtag
With the help of Xilinx Support i was able to figure out the steps that are needed to boot a full linux image via Jtag, these xmd console commands are:
1) connect arm hw
2) source ps7_init.tcl
3) ps7_post_config
4) ps7_init
5) source stub.tcl
6) fpga -f top.bit (in my case it was top.bit but your's may be named different)
7) target 64
8) mcr p15 0 c1 c0 0 0x08c5187a
9) dow "u-boot.elf"
10) con; sleep 1; stop
11) target 64
12) mcr p15 0 c1 c0 0 0x08c5187a
13) dow -data "zImage" 0x00008000
14) target 64
15) mcr p15 0 c1 c0 0 0x08c5187a
16) dow -data "system.dtb" 0x02408000
17) rwr r2 0x02408000
18) rwr pc 0x00008000
19) con
These commands are the exact commands that petalinux-boot uses when attempting to load a image via jtag.
Can you follow the steps mentioned on pages 44 and 45 of Zynq CTT. Let me know if you still get the error:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/ug873-zynq-ctt.pdf
Thanks for the reply,
I also found that pdf after posting my question, i have been successfully able to load a image through jtag by following that guide. My last remaining question is though, when i use petalinux it does not provide a uImage or uramdiskimage.gz but rather provides a zImage and rootfs.cpio. Is there a way to convert the data files that petalinux gives me to the format that the guide asks for?
Thanks for the help!
1) connect arm hw
3) ps7_post_config
4) ps7_init
5) source stub.tcl
7) target 64
9) dow "u-boot.elf"
11) target 64
14) target 64
19) con
