steven.starnes
Bootgen 2018.2 exception level is incorrect
I appear to have an issue when creating a boot image via bootgen.
the_ROM_image:
   [bootloader, destination_cpu = a53-0]FSBL.elf
   [destination_device=pl]bitStream.bit
   [pmufw_image]pmufw.elf
   [destination_cpu = a53-0, exception_level = el-2]app.elf
I generate the boot image via command line and it all runs fine and I flash the image. However whenever I attach to the process and debug from the XSDK the application is running at EL3. It appears the FSBL isn't reading the exception_level parameter and adjusting before launching. Let me know if I need to do something else.
gudishak
Hi @steven.starnes,
bl31.elf(ATF) proivides interfaces to application/OS to run/execute the secure instructsions or access the secure region.
So once you boot bl31 then it expects calls from Application/OS to run by its services. May be thats why it is able to run in EL3 without bl31. Once you load bl31 it expects application will run in EL0/1 and use its services.
Kranthi
Best Regards
Kranthi
gudishak
Image result for arm exception levels
EL3 is only to run ARM trusted applications. EL0/1 are for general applications.
As you are debugging application, ARM core will run in EL3.
Kranthi
Best Regards
Kranthi
steven.starnes
@gudishak Thank you for the response! So the underlying issue I am having is that if I load a BL31.elf before my app.elf the exception level doesn't change to what my application needs it to be to boot. See below for the bif file:
the_ROM_image:
[destination_cpu = a53-0,exception_level=el-3,trustzone]bl31.elf [destination_cpu = a53-0, exception_level = el-3]app.elf }
The app.elf was built using the XSDK bsp 2018.2 which requires the exception level to be at 3 or 1 and my app.elf needs to run at EL3. I thought that since I put the  exception_level to be set to el-3 the boot loader would set the exception level before handing execution to my application. However, while debugging I noticed my application is executing at exception level 0 not 3. If I remove the bl31.elf from the bif file the application runs fine.
gudishak
Hi @steven.starnes,
Kranthi
Best Regards
Kranthi
steven.starnes
@gudishak Okay that makes sense then. Thank you for your help!
