Visitor eichest
Bootgen Source Code
Hello everyone
I've read in the Software Developers Guid http://www.xilinx.com/support/documentation/user_guides/ug821-zynq-7000-swdev.pdf that the source code of the bootgen utility should be available (Appendix A.1). Could someone tell me, where I can find it and under what type of license the sources are released?
Best regards,
Stefan
Re: Bootgen Source Code
The bootgen source isn't available. You will need SDK to use bootgen.
Visitor stoschmann
I'd like to push this up because I have exactly the same question. We need to implement the bootgen in our build environment, so I'd like to get the sources as well.
Participant rankeney
I know it's been a while, but I just had a similar need and documented how I do it here:
https://zynqing.wordpress.com/2017/10/05/creating-a-zynq-compatible-bootgen/
Robert
