peltier
Bootgen and U -boot
I am generating a boot image with bootgen.
( The 1st DDR ram address is :  0x100000)
In some examples, the load adress is written, as:
[load = 0x100000, startup = 0x100000]C:\Bootgen_result\u-boot.elf
In other examples, it is only written:
What is the correct line?
Thanks by advance.
Gilles Peltier
sadanan
Hi @peltier,
For elfs, you dont have to specify the load and start addresses. Bootgen determined them from the elf itself. Specifying load and start address are more meaningful in case of binary files. If you specify them for elfs, Bootgen will ignore the addresses read from elfs
sadanan
Hi @peltier,
peltier
thank you, Sadanan
