dbrinks
Bootgen errors when using authentication
When I try to generate an authenticated bootloader, bootgen fails with the error:
FATAL: Exception: Sanity check in GetModulesExtension Failed
Has anyone seen this before (or successfully generated an authenticated bootloader)?
A few more details:
  • I've got Xilinx 14.6 tools installed
  • My command line is: "bootgen -image bootgen_sign.bif -o i BOOT_signed.bin -w on -efuseppkbits efusebits.txt -p xc7z020clg484 -encrypt bbram
  • My .bif files contains:
image : {
    [aeskeyfile]inc_key.nky
    [pskfile]rsa_keys_p_u.pem
    [sskfile]rsa_keys_s_u.pem
    [bootloader,authentication=rsa]fsbl.elf
The two PEM files are both unencrypted and were generated using ssh-keygen. They look like this:
-----BEGIN RSA PRIVATE KEY-----
<base64 encoded data>
-----END RSA PRIVATE KEY-----
I've used the inc_key.nky file before to perform encryption, so that shouldn't be the problem.
Thoughts?
htsvn
This issue is reported for Windows. Can you try this on a different OS?
--HS
htsvn
--HS
dbrinks
That seems to fix it--any chance of this being fixed for Windows at some point?
orazey
I am having the same problem what operating system did you use? And is your image secure RSA or non secure RSA?  Is  "[aeskeyfile]inc_key.nky" needed in both cases and the attributes will decide whether it is secure or non secure RSA? How did you generate this key in bootgen?
Lastly, how did you go about blowing the PPK eFUSE and generating the PPK hash for it?  Is this done automatically when  booting the RSA image?  I know its alot of questions and any help would be greatly appreciated.
