Build a PowerPC Outside EDK with Precision
I'd like to use Precision to synthesize my PowerPC implmentation. I've tried making an ISE project and copying the libraries to a local drive and adding them to the ISe project. I have nothing but problems in getting it to build (even with XST) even though EDK builds with XST. It would help if I could see a tcl script or some list of files that EDK is going through when it builds the PowerPC.
Xilinx - take a snoop at how easy it it to work with Actel embedded processors.........
Synthesizing an EDK project with third party tools involves a different flow then you typically would use as you have already found....
Here is a set of steps that can be used for third party syntheis of an EDK design:
http://www.xilinx.com/support/answers/24910.htm
