Anonymous
Not applicable
Build error or SDK not finding tools
Hi all,
I have been struggling with a build error shown belowI have been thru the forums and answers and tried to make sure I have eliminated the obvious but I am still missing something and was hoping someone could spot it for me.
Running libs - 'make -s libs "COMPILER=mb-gcc" "ARCHIVER=mb-ar"
"COMPILER_FLAGS=-mlittle-endian -mno-xl-soft-mul -mxl-barrel-shift
-mxl-pattern-compare -mcpu=v8.00.b -O2 -c" "EXTRA_COMPILER_FLAGS=-g"'.
Compiling common
make[1]: *** [libs] Error 127
Compiling llfifo
Compiling standalone
make[1]: *** [standalone_libs] Error 127
make[1]: Target `libs' not remade because of errors.
Compiling axidma
Compiling gpio
Compiling axiethernet
Compiling cpu
ERROR:EDK:369 - make failed for target "libs"
ERROR:EDK:3418 - Error(s) while running make.
make: *** [microblaze_0/lib/libxil.a] Error 2
make: Target `all' not remade because of errors.
I am trying to build a BSP from within the SDK using the SP605 Embedded Kit tutorial projects downloaded from Xilinx.  The project also fails to compile the "hello_world" default C project but I assume the errors are the same and for some reason the tools either can't be found or are missing.
I have tried (re)installing 12.4 several times but no change in results.  I am running the SDK from the proper shortcut so I believe the correct settings32.bat file is being executed and the proper environment variables exist but not sure how to validate.  The following is the path that is given when the XInfo System Checker is executed:
Path: C:\Xilinx\12.4\ISE_DS\common\\lib\nt;C:\Xilinx\12.4\ISE_DS\ISE\lib\nt;C:\Xilinx\12.4\ISE_DS\common\\bin\nt;C:\Xilinx\12.4\ISE_DS\ISE\bin\nt;C:\Xilinx\12.4\ISE_DS\PlanAhead\bin;C:\Xilinx\12.4\ISE_DS\EDK\bin\nt;C:\Xilinx\12.4\ISE_DS\EDK\lib\nt;C:\Xilinx\12.4\ISE_DS\common\bin\nt;C:\Xilinx\12.4\ISE_DS\common\lib\nt;C:\Program Files\Common Files\Microsoft Shared\Windows;C:\Program Files\Windows Live\Shared;C:\Program Files\CMake 2.8\bin;C:\Program Files\msm2msi
Two of the above path lines have double slashes "\\" and was not sure if that created an issue or not.
Thanks in advance,
Mike
vsiva
It looks like a Cygwin issue. Can you launch a cygwin shell from within SDK? Try doing a make within that shell and see if you notice any errors.
vsiva
Anonymous
Not applicable
vsiva -
Thanks for the advice and you figured correctly.  It was an older version of the cygwin.dll that was in my system folder from another application that was creating the problem.  Once I deleted it and rebooted - everything worked properly.
I am new to the toolset and was not familar with building/compiling via command shell so in doing some further research on the forums I turned up other responses regarding multiple versions of cygwin running.  Which lead me to do a search on my computer.
As a follow up question could you point me to some tutorials/guides for building projects via the shell.  I think it would be nice to have that capability.
Thanks again,
Mike
