Visitor atamez
C_PIM*_DATA_WIDTH mpmc parameter for VFBC
   I am working on an MPMC system on a Spartan-6 LX150T with a single VFBC write and a single VFBC read port. I am running at a data rate that is about half of what is reported in the MPMC data sheet. (800 MB/s). My data rate is about 572 MB/s.
http://www.xilinx.com/support/documentation/ip_documentation/mpmc/v6_04_a/mpmc.pdf
page 215
I am looking at the generated .mhs and mpmc_0_wrapper.v files and notcied that the C_PIM0_DATA_WIDTH parameter is set to 32.   I would have expected this to be 64 for VFBC based on the excerpt below from MPMC data sheet, page 222.
The VFBC PIM uses the NPI interface of the MPMC, therefore the latency and throughput of the VFBC PIM is
similar to the NPI PIM. The maximum throughput of the VFBC PIM is 95.2% of the NPI PIM throughput (see
Table 94, page 211). The VFBC uses 32-word bursts and 64-bit NPI interface only; consequently, only those
configurations from Table 94, page 211 are valid for the VFBC numbers.
Am I interpreting this wrong?
The reason I am doing a deeper dive into the MPMC and VFBC instance definitions is an issue in simulation where I see the VFBC_Wd_Full flag asserted. I am trying to track down where my BW estimation or understanding is mistaken.
Andres
Re: C_PIM*_DATA_WIDTH mpmc parameter for VFBC
I don't have an answer to your specific questions, but keep this in mind:
http://www.xilinx.com/support/answers/47936.htm
That issue had similar symptoms with the full flag being asserted incorrectly.
Also see:
http://www.xilinx.com/support/answers/43996.htm
www.xilinx.com
Visitor atamez
Thanks for the quick response. I don't think those will help solve my issue but I am simulating with the modified vfbc_backend_control.vhd to see if it makes a difference.
Visitor atamez
I have a related question on MPMC - regarding the C_PORT_CONFIG parameter. This allows us to select between Unidirection/Bidirectional ports of various widths. How does this parameter relate to:
A) The VFBC 64-bit NPI width parameter in the datasheet (see op).
B) The C_PIM_DATA_WIDTH parameter
C) The C_VFBC0_RDWD_DATA_WIDTH parameter
Andres
