Anonymous
Not applicable
C++ boost library with microblaze
Hi there,
I am a  beginner in the SDK world. I am trying to target a development board (KCU105) with the Microblaze processor.
My problem arises as I am also trying to use the Boost libraries, with no success so far.
Is there a way to compile these libraries with the mb-gcc compiler? If so, how?
Or is there a better way to do this?
Thank you for your help.
Best,
JC
shabbirk
Refer the below link to setup microblaze toolchain. once it is done you can build your C++ boost libraries using gcc c++ commands:
http://xilinx-john.wikidot.com/mb-gnu-tools
Best Regards
Shabbir
Anonymous
Not applicable
Hi Shabbir.
Thank you very much for your response.
I am not using a Linux environment. Also I believe the microblaze toolchain is set up on my SDK (?) as it can be seen in the attached.
The path to the bin folder for the mb-gcc and mb-g++ commands is included in the PATH environment, but when I try to build the boost libraries (in windows cmd console) it does not recognize the tools.
Any further help is appreciated.
Best,
Jorge
I think u might have solved the issue by now. Now I am trying to link boost library with Z702 with no success in linking boost c++ libraries. Can you please let me know how u have done that before so that will be useful for me.
Any advice is appreciated
