CMake Object Option file flag.
we are using SDK 2018.2 for the build / linking and we are getting an error on CMake Build Environment.
"<drive>:/Xilinx/SDK/2018.2/gnu/armr5/nt/gcc-arm-none-eabi/bin/armr5-none-eabi-ld.exe"
we have multiple object files. If we want to give these objects as input to linker through a single option file, which linker flag should we use?
ibaie
Hi vaibhav.patil@zf.com
Not sure if you are still dealing with this issue but just for records, ld is GNU linker so you can take a look to the GCC documentation to get more details about the options.
Using LD, the GNU linker
Ibai
