Gloria_gao
CSI RX Subsys example zcu
I created the example project of mipi csi rx susbsys of zcu102, however, I can not find the vitis part in the folder.
Where can I get the vitis part?
Besides, does mipi csi rx ip have to be configured to receive data from sensor?
Can I configure it by PL instead of PS?
florentw
HI @Gloria_gao
Refer to the latest pg232 (chapter 5). You need to create a platform in Vitis and import the example application
florentw
HI @Gloria_gao
Gloria_gao
Thank you!
