Can Matlab call XSCT tcl file?
Hello
I am developing standalone app in MPSoC in windows environment. I have a tcl file (boot.tcl) which initilizes the FPGA, download .bit., .elf and memory.
Now, I hope to do these tasks in Matlab. So our developed algorithms can be done in Matlab and directly be uploaded to FPGA memory. I know Matlab has system command to start XSCT
system('xsct.bat&')
This executes xsct and pops up the console.
What I want is also to execute
xsct% source boot.tcl
I am wondering if the xsct commands can be called in Matlab
Thank you
This is a bug in XSCT. The handler for version command is not registered in non-interactive mode, hence the error. All other commands should work. You can test your example with 'help' command
after some searching, it is discussed in 'non-interactive' mode of XSCT document.
Can anyone point out what is wrong here?
I have made a foo.tcl to test.
version
it only has one line, which prints out
2018.2
if I use interactive mode of XSCT
xsct% source foo.tcl
I get the correct output.
However, if I try to run Windows command line
xsct foo.tcl
I have the following error messages
invalid command name "::xsdb::get_version"
    while executing
    (procedure "version" line 20)
    invoked from within
"version"
    (file "a.tcl" line 2)
