Voyager
Voyager
Can data2mem be used for ARM/MIPS cpu or dsp processor?
It is only for PPC or MB?
Yes.
Data2MEM can even be used for systems without any processors.  However, its up to the user to hand create the .bmm file which maps the address range to individual BRAM instances.
Hope this helps,
Dylan
Voyager
Voyager
It needs elf or mem file except for bit?
Hi m006,
As advised in your other post, please use the "data2mem_standalone.pdf" document attached.
*NB* I know you have this, however I am just attaching it here so that other people who view this post can get it too.
Kind regards,
Gareth
 What data2mem does is it places the application binary file (whether this be elf, mem, or whatever) in Block RAM. The Processor only needs to have access to this data and the data is in a format that the processor can read
