Participant ucabsdp
Can not ping or connect to LwIP Echo Server SDK example Zedboard.
I want to test out the LwIP functionality to send some large data to the board. I thought running the Echo Server demo would be an instructive exercise, but unfortunetatly I can not seem to get the demo working. Any suggestions? This is for a Zedboard, so I simply created a Zynq base design in vivado and then exported this to the SDK, and created the new demo project as per.
Sam
Tags (3)
Participant ucabsdp
Re: Can not ping or connect to LwIP Echo Server SDK example Zedboard.
OK so, the SDK example is working, it appears that I was just very very unlucky! Out of all of the ethernet cables in my office (a lot) I happened to choose the only 2 that were broken, plugged in one from a working LAN network and it's working. Sorry for that. But many thanks for your help!
Participant ucabsdp
This is a nightmare, just running the XAPP1026 ready to download data and that won't even download. I Download fsbl.elf, execute con and then stop. But then when try to download raw_apps.elf I get:
XMD% dow raw_apps.elf
Processor started. Type "stop" to stop processor
User Interrupt, Processor Stopped at 0xfffffe1c
Downloading Program -- raw_apps.elf
section, .text: 0x00100000-0x00123a77
section, .init: 0x00123a78-0x00123a8f
section, .fini: 0x00123a90-0x00123aa7
section, .rodata: 0x00123aa8-0x001251bb
section, .data: 0x001251c0-0x00125e2f
section, .eh_frame: 0x00125e30-0x00125e33
section, .bss: 0x00125e34-0x0090f28b
section, .mmu_tbl: 0x0090f28c-0x00913fff
section, .ARM.exidx: 0x00914000-0x00914007
section, .init_array: 0x00914008-0x0091400f
section, .fini_array: 0x00914010-0x00914013
section, .heap: 0x00914014-0x0095401f
section, .stack: 0x00954020-0x00a94c1f
Download Progress.ERROR: Failed to download ELF file
Cannot access DDR: the controller is held in reset
Scholar sampatd
Which version of the tool are you using?
Participant ucabsdp
Currently using SDK (and vivado) 2013.3
Scholar sampatd
That should be ok. Have you run the PS initialization commands before downloading the application raw_apps.elf ?
Follow this order:
connect arm hw //connect to arm processor
source proc/hw_platform_0/ps7_init.tcl //source the initialization tcl file
ps7_init //initialize the ps peripherals
fpga -f output/arm_subsystem_wrapper.bit //configure the PL side (optional)
ps7_post_config //set the level shifters (only required when using the PL logic)
dow proc/test //download the application file
run //execute the application/Debug/test.elf
Participant ucabsdp
I will try this, but shouldn't all the config already be handled by the fsbl.elf in the ready to download package?
Participant ucabsdp
I tried what you said and am still getting the same error,
I did the above,
Then downloaded and ran fsbl.elf
Then attempted to download raw_apps.elf
Participant ucabsdp
If I just run the ps7_init and then download raw_apps.elf it downloads but when running I cannot still receive a ping from the device.
Scholar sampatd
Can you post a screenshot/log ?
Participant ucabsdp
Scholar sampatd
Thanks for clarifying.
