Observer kjbernardo
Can't PING SFP in Kintex7
I created an environment in XPS for Ethernet to work using SGMII and Soft Temac 10/100/1000. I was able to successfully ping the board. When I tried to change the RX and TX ports of SGMII with the RX and TX ports of SFP and added the port SFP_TX_DISABLE_TRANS as well as the jumpers stated in the datasheet of Kintex7, not even link up is possible. I can't seem to ping the board.
Can anybody help me with this issue?
kjbernardo
Observer kjbernardo
Re: Can't PING SFP in Kintex7
Anyone?
Really need help. I might have overlooked something.
Did you changed the core to 1000Base_x configuration when using SFP.
You can also check the link up debugging section of PG047.
Satish
Observer kjbernardo
When I tried to switch to 1000BaseX Ethernet, I can't ping as well. Tried it when the TX and RX ports are connected to the SFP pin locations and also with the Ethernet locations.
can you see link up with this core.
Satish
Observer kjbernardo
No, I can't see no link up when using 1000BaseX.
Does this work in loopback.
What is the value of status vector and is AN enabled at both ends.
Satish
Observer kjbernardo
No, I haven't tried the loopback test. I'm using the LogiCore IP AXI Ethernet v3.01. With the changes in the UCF file, I was able to use 1000BaseX with a linkup between the board and PC but still can't ping. With the SGMII settings, no linkup can be seen.
Observer kjbernardo
When in 1000BaseX Ethernet PORTS are connected, this is the output but still can't PING.
-----lwIP TCP echo server ------
TCP packets sent to port 6001 will be echoed back
Board IP: 192.168.1.10
Netmask : 255.255.255.0
Gateway : 192.168.1.1
auto-negotiated link speed: 1000
TCP echo server started @ port 7
When in 1000BaseX in SFP PORTS, here is the output.
What jumpers do I need or ports that I need to configure? Thanks
