Observer yingcai
Can't assign result getting form ip-core to a variable declared in SDK
Hey guys,
I can get the value from my IP-core, the code is like this:
Setup_HW_Accelerator(A, B, A, dma_size);
for (int ii = 0; ii < NUM_TESTS; ii++) { //NUM_TESTS = 10
	Start_HW_Accelerator( );
	Run_HW_Accelerator(A, B, A, dma_size); //Get value from custome IP-core
the value here refers to the float type array A[32][32]. However, if I try to assign the array A[32][32] to a new array which is the same type and declared in the same scope, the code is like this:
	for(int idn = 0; idn < 32; idn++){
	        for(int jdn = 0; jdn < 32; jdn++){
			preserve[idn][jdn] = A[idn][jdn];
After 10 iterations, then I print out the result, array A[32][32]'s result indicates it is only being iterate for 1 time. The array preserve[32][32]'s result indicates its result is assigned by array A[32][32]'s first iteration result.
Why is that?????  Can anyone help?????
Yingcai.
